![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2015 Location: Morocco
Member: 2384687 Status: Offline Thanks Meter: 14 | s926bxxs3axfe fmm and kg locked . test point not work is there any solution ? https://ibb.co/R409j6Yh https://ibb.co/Zz3wBsbv chimera don't connect with phone in test point thank you |
![]() | #2 (permalink) |
Member: 2384687 Status: Offline Thanks Meter: 14 | https://ibb.co/5h0hB3nF another pic shows the problem |
![]() | #3 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,767 | Dear User, Unfortunately, test point is disabled on this device due to the KG lock. You would need to try to enable ADB mode using the camera. (reset the phone and tap the screen until the camera opens then scan the QR code). Once you are in ADB mode, you can run the KG remove procedure. Regards, ChimeraTeam Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
![]() | #4 (permalink) |
Member: 2384687 Status: Offline Thanks Meter: 14 | but amazon locked the phone when i connect wifi . is there any solution ? https://ibb.co/5h0hB3nF thank you |
![]() | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 25,767 | Dear User, You would need to reset your phone so that you are on the "Hello" screen then tap the screen multiple times until the camera opens, then scan the QR code with the camera. This will enable ADB. Then, connect the phone to the computer in ADB mode and run the KG Removal procedure. Regards, ChimeraTeam Quote:
![]() | #6 (permalink) | |
Member: 2384687 Status: Offline Thanks Meter: 14 | not work . because when i connect wifi the phone get locked by amazon Quote:
