06-23-2021, 10:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | N950f u15 sf uf patch cert done Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N950F Carrier ID: MID Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Mar 24 14:51:31 KST 2021 PDA Version: N950FXXSFDUD4 [april 2021, rev4] Phone Version: N950FXXSFDUD1 [april 2021, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58K327RV6R Imei: 354136040 Imei2: 35413604 Battery Status: 3.74V (32%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 0174CD325A12 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [06.23.21 12:53:50] WorkID: 139351781 |
06-23-2021, 11:37 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear mathew_di, Thank you for the report, good job from you! Best regards Sab Chimera Team Quote:
10-28-2021, 18:11 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: attock Age: 35
Member: 1147735 Status: Offline Thanks Meter: 156 | Strange lroblem n950f u15 After patch done 100% signal ok but after restart again emergency call only. And service mode imei status NG But if i try again and again restart some time signal back 100% But the problem is come after restart Please All master any solution please share Phone model is same with 1 post and same all operating log |
10-29-2021, 10:01 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear User, Please reflash the device and then do the IMEI REPAIR and the PATCH CERT. Make sure that you enable the Airplane mode, and then you repeat the PATCH CERT. It is a litlle trick, but in same cases it will help you out. Best regards Sab Chimera Team Quote:
