![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: Bogotá Colombia Age: 44
Member: 150844 Status: Offline Thanks Meter: 315 | samsung a32 patch cert not work Today i tried redo repair and patch but get no network, after reflash and do process again same problem,inclusive whit diferent root versions , none work . please recheck patch cert procedure , seems broken after update. Code: Chimera Mobile Phone Utility version: 42.42.1315 @ 2025-03-13 Printing phone history Update Firmware 13/03/2025 9:11 p.*m. Patch Certificate 13/03/2025 9:07 p.*m. Patch Certificate 13/03/2025 9:05 p.*m. Update Firmware 13/03/2025 9:02 p.*m. Patch Certificate 13/03/2025 8:58 p.*m. Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325M Carrier ID: COM Sales Code: TPA Country Code: PANAMA Timezone: America/Bogota Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Thu Oct 17 01:27:52 KST 2024 PDA Version: A325MUBSADXJ1 [october 2024, rev1] Phone Version: A325MUBSADXJ1 [october 2024, rev1] CSC Version: A325MOWOADXJ1 [october 2024, rev1] Board Platform: MT6768 Modem Platform: MT6765 Serial Number: R58RB Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2024-10-01 Em Did: 204D2A5B4A692411 Bootrom commands disabled: no Preparing... Checking boot... Backing up partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Creating PROTECT1 backup PROTECT1 partition can be restored with the "Store/Restore Backup" function in case of any error Creating PROTECT2 backup PROTECT2 partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.13.25 16:32:04] WorkID: 351021713 |
![]() | #2 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,767 | Dear User, The Patch cert procedure is not broken. You should do a factory reset the phone and reflash it then root the phone. Once the phone is rooted run the IMEI Repair and then the Patch Certificate procedure. Regards, ChimeraTeam Quote:
![]() | #3 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 315 | Of course i do all steps , full flash , root , repair an patch but always the same no network , *# 0011 # does not show noting and signal cross |
