Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 07-26-2021, 18:22   #1 (permalink)
Member: 2092797
Thanks Meter: 5
Samsung a71 no service after read codes
WorkID: 143743101
can not serch networks neither make calls
no signal
Thanks in advance...
Old 07-26-2021, 20:17   #2 (permalink)
Member: 2092797
Thanks Meter: 5
Flash, same version still the same
Old 07-27-2021, 09:52   #3 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 19,423
reply
Dear glma5,
Please run the READ CODES method again on the device. Of course we wont charge you credits.
Best regards
Sab
Chimera Team
Old 07-27-2021, 17:53   #4 (permalink)
Member: 2092797
Thanks Meter: 5
redone still the same is rare, have not had any problem like that before
Old 07-28-2021, 10:13   #5 (permalink)
Member: 1787203
reply
Dear glma5,
Yes, it is strange. Please try to reflash the device with the serial number. Connect the device to the tool in ADB mode. Click on the Firmware Update. Then click on the AUTO DETECT and the tool will find the latest, official firmware for it.
Best regards
Sab
Chimera Team
Old 07-28-2021, 19:12   #6 (permalink)
Member: 2092797
Thanks Meter: 5
done, newest firmware still the same
Old 07-29-2021, 10:19   #7 (permalink)
Member: 1787203
reply
You get this issue only with a different SIM CARD then the original? Or with the ORIGNAL as well?
Best regards
Sab
Chimera Team
Old 07-29-2021, 13:22   #8 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,200
Hi, did you check that your device is not blacklisted on your country network before unlock? please attach image with *#0011# with simcard inserted, go to simcard 1 then post screenshot here...
Old 07-29-2021, 19:48   #9 (permalink)
Member: 2092797
Thanks Meter: 5
make a call using 112, did not have original sim, check on IFT is blacklist for Mexico is clean i attach photo later
Old 07-29-2021, 19:50   #10 (permalink)
Member: 2092797
Thanks Meter: 5
https://ibb.co/NtfkMCz
Old 07-30-2021, 10:03   #11 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the picture. We are investigating the issue as sadly we do not experienced such a problem before. I hope we can find a solution pretty soon!
Best regards
Sab
Chimera Team
Old 07-30-2021, 13:26   #12 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,200
Hi, MIPI DEVICE fail is hardware issue not related to read codes procedure... you need fix this phisical failure then your device will be ok...
Old 07-31-2021, 21:51   #13 (permalink)
Member: 2092797
Thanks Meter: 5
yes i am on it funny thing was working and making 112 call and then fail strange thanks
Old 08-01-2021, 05:06   #14 (permalink)
Member: 2465890
Thanks Meter: 62
MIPI error that's mean hardware Issue. Check your device again.
Old 08-02-2021, 17:47   #15 (permalink)
Member: 2092797
Thanks Meter: 5
i am going for hw but 112 call was made and then later not bad luck thanks anyway
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17787 seconds with 7 queries
