Samsung G386T Unlock Done Samsung G386T - Flash The Handset Using The File using ODIN After the Flash it will recognize as G386T1 Now do the Unlock Normal http://www.gsm-hosting.net/Arquivos/.../images/jj.png Code: [Unlock phone started] |
do you have any firmware for sm-G360T that can change it for unlock? |
Unlock App and no code asking in newest T-Mobile and Metro handsets and you only can unlock buying a code server to unlock app unlock. The new models MetroPCS no longer accept IMEI unlock code for it but to bring UNLOCK preinstalled APP, this APP communicates with the server of the company and be authorized if the unlock, do it. This APP is incorporated with the phone, what you buy is only an authorization to unlock the IMEI Possible solution not tested by me: https://download.chainfire.eu/767/CF...mo-smg360t.zip Root with autoroot via Odin and then unlock with some other tool. ;) |
Br LuisinhoCell |
I tried same but after unlock it just goes to searching and no service. When I reflash firmware for SM-G386T it just re-locks to network and when I again repeat the procedure it just goes to searching again . is there anyway to fix this probelm |
reply Dear Sir, could you write me the work id of the problematic process please? Thank you in advance! Best regards Nicole Quote:
