![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Apr 2013
Member: 1927285 Status: Offline Sonork: Abdu Thanks Meter: 21 | Samsung g935k patch cert no work signal Chimera Mobile Phone Utility version: 21.21.1206 @ 2019-05-24 Printing phone history Patch Certificate 22.05.2019 11:41:50 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935K Sales Code: KTC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Jan 18 18:12:32 KST 2019 PDA Version: G935KKKU2ESA2 [january 2019, rev2] Phone Version: G935KKKU2ESA1 [january 2019, rev1] CSC Version: G935KKTC2ESA2 [january 2019, rev2] Product Code: KTC HIDSw Version: G935KKKU2ESA2/G935KKTC2ESA2/G935KKKU2ESA1/G935KKKU2ESA2 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R39HA0DNMY Imei: 355915070339148 Unique Number: CE10160A80EA572D04 Connections: AT,MTP Battery Status: 3.80V (18%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-01-01 Data Encryption State: unencrypted Patching certificate... Initializing. Reading modem. Be patient! Do NOT disconnect the phone! Preparing. Reminder! In case of new firmware flashing or modem replacement, the Patch Cert process must be repeated! Succeeded. Successfully finished. Finished at local time: [05.24.19 14:33:06] WorkID: 60563224 |
![]() | #2 (permalink) |
Member: 1927285 Status: Offline Sonork: Abdu Thanks Meter: 21 | method 1 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935K Sales Code: KTC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Jan 18 18:12:32 KST 2019 PDA Version: G935KKKU2ESA2 [january 2019, rev2] Phone Version: G935KKKU2ESA1 [january 2019, rev1] CSC Version: G935KKTC2ESA2 [january 2019, rev2] Product Code: KTC HIDSw Version: G935KKKU2ESA2/G935KKTC2ESA2/G935KKKU2ESA1/G935KKKU2ESA2 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R39HA0DNMY Imei: 355915070339148 Unique Number: CE10160A80EA572D04 Connections: AT,MTP Battery Status: 3.79V (18%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-01-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Previous patchcert successfully removed. Checking modem. Checking root. The phone is rooted by: 3.12:EFTSU Checking boot image. Be patient! Do NOT disconnect the phone! EFTSU root detected. Cannot patch boot image. Selinux could cause problems. If the patchcert does not work, try another root solution. Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [05.24.19 14:40:24] WorkID: 60563638 |
