08-08-2019, 10:33 | #16 (permalink) |
Crazy Poster Join Date: Nov 2016
Member: 2645643 Status: Offline Sonork: The Programmer Thanks Meter: 7 | |
08-08-2019, 10:43 | #18 (permalink) | |
Member: 2645643 Status: Offline Sonork: The Programmer Thanks Meter: 7 | Quote:
08-08-2019, 13:52 | #19 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, We are checking and investigating all the reported works with the mentioned modem version. The team is already working on an update which hopefully will help us out. We need your patient because we need time to release a fix for it. Best Regards Chimera team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
08-13-2019, 22:24 | #22 (permalink) |
Member: 2645643 Status: Offline Sonork: The Programmer Thanks Meter: 7 | Now that is very strange since am also on the same firmware as yours. But am getting modem firmware not supported. Could I BE MISSING SOMETHING OUT WITH THE WHOLE PROCESS. Please care to share your success maybe it could help the support team make a stable solution. |
04-08-2021, 10:44 | #26 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, What is the issue exactly? Please explain it. You can also post a WORK ID so we can check the job. Best regards Sab Chimera Team Quote:
05-13-2021, 21:59 | #27 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2368708 Status: Offline Thanks Meter: 2 | this is the frp bypass file https://www.programdestek.com/g935f-...u8-frp-bypass/ |
05-14-2021, 09:42 | #28 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, We already have a new FRP RESET method for the G935F device. If you looking for a solution, i would recommend to use the RESET FRP ONLINE method in the Chimera Tool. Best regards Sab Chimera Team Quote:
