![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Apr 2013
Member: 1927285 Status: Offline Sonork: Abdu Thanks Meter: 21 | SAMSUNG G965F emergency call Code: Chimera Mobile Phone Utility version: 21.22.1406 @ 2019-05-25 Printing phone history Patch Certificate 25.05.2019 16:52:57 Knoxguard Unlock 25.05.2019 16:24:16 Patch Certificate 25.05.2019 15:51:39 Patch Certificate 25.05.2019 15:45:40 Patch Certificate 25.05.2019 15:44:22 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Sales Code: SER Country Code: Russia Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Dec 20 07:52:17 KST 2018 PDA Version: G965FPUU2CRLI [december 2018, revI] Phone Version: G965FXXS3CSD2 [april 2019, rev2] CSC Version: G965FSER2CRLI [december 2018, revI] Product Code: SER HIDSw Version: G965FPUU2CRLI/G965FSER2CRLI/G965FXXS3CSD2/G965FPUU2CRLI Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K75B9FCE Imei: 358954091475539 Unique Number: CE031823633B1025057E Connections: AT,MTP Battery Status: 3.96V (58%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-12-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.2:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. Do not check the status of the imei! It is important that the SIM card is on the phone at startup and the PIN authentication is turned OFF. The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [05.25.19 23:10:46] WorkID: 60734855 |
![]() | #2 (permalink) |
Member: 1927285 Status: Offline Sonork: Abdu Thanks Meter: 21 | Root from https://chimeratool.com/en/docs/gala...-sm-a750f-root court took |
