03-14-2023, 11:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Algérie Age: 45
Member: 2269857 Status: Offline Thanks Meter: 364 | Huawei Y9 Prime 2019 CATEGORY Huawei MODEL Huawei Y9 Prime 2019 DATE Mar 14, 2023, 10:39:15 AM |
The Following User Says Thank You to drisso12 For This Useful Post: |
03-14-2023, 16:41 | #3 (permalink) |
Member: 2269857 Status: Offline Thanks Meter: 364 | not convert bro 1 ime plz hellp hi Chimera Mobile Phone Utility version: 35.12.1127 @ 2023-03-14 Printing phone history Modify Oeminfo 14-03-2023 8:28 Imei Recovery 14-03-2023 8:28 Modify Oeminfo 08-03-2023 8:21 Get Info 08-03-2023 8:19 Imei Recovery 08-03-2023 8:19 Update firmware Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing CUST_VERLIST. Processing CUST_VER. Processing PACKAGE_TYPE. Processing PTABLE_CUST. Processing VERSION. Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing PRETS. Processing PRETVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing KPATCH. Processing USERDATA. Processing UFSFW. Opening the file Unpacking the archive... Unpacking the archive... Processing PRELOAD_VERLIST. Processing PRELOAD_VER. Processing PACKAGE_TYPE. Processing PTABLE_PRELOAD. Processing PRELOAD. Pre-processing APP files Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_RqOVmuptable.app Validating base file Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_OIUpJpupdate.app Validating customization file Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_wRImJEupdate.app Validating preload file Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_ieJJhBupdate.app Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_RqOVmuptable.app Flashing SHA256RSA Flashing CRC Flashing BASE_VERLIST Flashing BASE_VER Flashing PACKAGE_TYPE Flashing HISIUFS_GPT Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_eddzYyptable.app Flashing SHA256RSA Flashing CRC Flashing CUST_VERLIST Flashing CUST_VER Flashing PACKAGE_TYPE Flashing PTABLE_CUST Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_arJuUFptable.app Flashing SHA256RSA Flashing CRC Flashing PRELOAD_VERLIST Flashing PRELOAD_VER Flashing PACKAGE_TYPE Flashing PTABLE_PRELOAD Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_OIUpJpupdate.app Flashing SHA256RSA Flashing CRC Flashing BASE_VERLIST Flashing BASE_VER Flashing PACKAGE_TYPE Flashing HISIUFS_GPT Flashing XLOADER Flashing FASTBOOT Flashing DTS Flashing DTO Flashing VECTOR Flashing FW_LPM3 Flashing HHEE Flashing VBMETA Flashing TEEOS Flashing TRUSTFIRMWARE Flashing SENSORHUB Flashing FW_HIFI Flashing KERNEL Flashing MODEMNVM_UPDATE Flashing MODEMNVM_CUST Flashing MODEM_DRIVER Flashing RECOVERY_RAMDISK Flashing RECOVERY_VENDOR Flashing RECOVERY_VBMETA Flashing PREAS Flashing PREAVS Flashing PRETS Flashing PRETVS Flashing ERECOVERY_KERNEL Flashing ERECOVERY_RAMDISK Flashing ERECOVERY_VENDOR Flashing ERECOVERY_VBMETA Flashing ENG_VENDOR Flashing ENG_SYSTEM Flashing HDCP Flashing CACHE Flashing RAMDISK Flashing SUPER Flashing SUPER Flashing VBMETA_SYSTEM Flashing VBMETA_VENDOR Flashing VBMETA_ODM Flashing VBMETA_HW_PRODUCT Flashing VBMETA_CUST Flashing ISP_FIRMWARE Flashing MODEM_FW Flashing HISEE_IMG Flashing PATCH Flashing KPATCH Flashing USERDATA Flashing UFSFW Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_wRImJEupdate.app Flashing SHA256RSA Flashing CRC Flashing CUST_VERLIST Flashing CUST_VER Flashing PACKAGE_TYPE Flashing PTABLE_CUST Flashing VERSION Processing C:/Users/ghani/AppData/Local/Temp/CHIMERA_ieJJhBupdate.app Flashing SHA256RSA Flashing CRC Flashing PRELOAD_VERLIST Flashing PRELOAD_VER Flashing PACKAGE_TYPE Flashing PTABLE_PRELOAD Flashing PRELOAD Restart the phone in normal mode Gathering phone information Processing phone information Current firmware version: 10.1.0.156 (C431E19) (hw/normal) @ VOG-L29 Finished at local time: [03.14.23 17:36:55] WorkID: 215203215 |
03-14-2023, 16:53 | #4 (permalink) |
Member: 2269857 Status: Offline Thanks Meter: 364 | Rebooting phone to USB update mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. New model name: VOG-L29 New vendor/country value: hw/normal Convert to dual sim Force hash overwrite It seems we could not read any related usable data from the phone for backup. Maybe it is already converted to dual sim. We've just rebooted your phone into USB update mode, please do an USB firmware update without further reboot, because it might reinitialize the FW version compatibility flag Finished at local time: [03.14.23 17:50:14] WorkID: 215206121 |
03-14-2023, 19:53 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply As we see you repeated the Modify OEM Info. After that, you flashed the phone. Is it workable now? If not, can you please do a GET INFO method on the phone with the chimera? So we can check the details. Best regards Sab Chimera team Quote:
