01-28-2021, 15:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Samsung Galaxy Note20 Ultra 5G SM-N986B ''U1'' patch cert Done by Chimera Tool Chimera Mobile Phone Utility version: 27.29.0708 @ 2021-01-27 Printing phone history Get Info 1/27/2021 8:51 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N986B Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 4 22:02:44 KST 2020 PDA Version: N986BXXU1ATI2 [september 2020, rev2] Phone Version: N986BXXU1ATI4 [september 2020, rev4] CSC Version: N986BOXM1ATI2 [september 2020, rev2] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R5CN80FLWTT Imei: 35 Imei2: 35 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35 Repaired imei: 35 Current imei2: 35 Repaired imei2: 35 Successfully finished. Finished at local time: [01.27.21 16:06:44] WorkID: 123300926 Chimera Mobile Phone Utility version: 27.29.0708 @ 2021-01-27 Printing phone history Repair IMEI 1/27/2021 2:05 PM Get Info 1/27/2021 8:51 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N986B Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 4 22:02:44 KST 2020 PDA Version: N986BXXU1ATI2 [september 2020, rev2] Phone Version: N986BXXU1ATI4 [september 2020, rev4] CSC Version: N986BOXM1ATI2 [september 2020, rev2] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R5CN80FLWTT Imei: 35 Imei2: 35 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.27.21 16:09:04] WorkID: 123301381 |
The Following 3 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
07-27-2021, 13:25 | #2 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Samsung Galaxy Note20 Ultra 5G SM-N986B ''U1'' Patch cert Done by EFT + Chimera Tool HOW DO THE DO IT. Chimera Mobile Phone Utility version: 29.04.1243 @ 2021-07-27 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N986B Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 4 22:02:44 KST 2020 PDA Version: N986BXXU1ATI2 [september 2020, rev2] Phone Version: N986BXXU1ATI4 [september 2020, rev4] CSC Version: N986BOXM1ATI2 [september 2020, rev2] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R5CN80CL9WD Imei: 35 Imei2: 35 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Em Did: 200877CD36982011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35 Repaired imei: 35 Current imei2: 35 Repaired imei2: 35 Successfully finished. Finished at local time: [07.27.21 13:11:31] WorkID: 143840904 Chimera Mobile Phone Utility version: 29.04.1243 @ 2021-07-27 Printing phone history Reboot 7/27/2021 11:12 AM Repair IMEI 7/27/2021 11:09 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N986B Carrier ID: XFA Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 4 22:02:44 KST 2020 PDA Version: N986BXXU1ATI2 [september 2020, rev2] Phone Version: N986BXXU1ATI4 [september 2020, rev4] CSC Version: N986BOXM1ATI2 [september 2020, rev2] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R5CN80CL9WD Imei: 35 Imei2: 35 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Em Did: 200877CD36982011 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.27.21 13:13:46] WorkID: 143841518 |
07-27-2021, 13:41 | #3 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,727 | reply Dear GMSR, Thank you again for the amazing post and work! Best regards Sab Chimera Team Quote: |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
