07-15-2020, 09:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Samsung J600g Patch certificate done Chimera Code: Chimera Mobile Phone Utility version: 25.39.1403 @ 2020-07-15 Printing phone history Get Info 7/15/2020 8:25:57 AM Knoxguard Remove 7/14/2020 1:27:36 PM Rmm Remove 7/14/2020 1:25:46 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600G Sales Code: CHL Country Code: Chile Timezone: Africa/Harare Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Feb 6 01:20:18 KST 2020 PDA Version: J600GUBS6BTB2 [february 2020, rev2] Phone Version: J600GDXS6BTB1 [february 2020, rev1] CSC Version: J600GOWA6BTB1 [february 2020, rev1] Product Code: CHL HIDSw Version: J600GUBS6BTB2/J600GOWA6BTB1/J600GDXS6BTB1/J600GUBS6BTB2 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K60NW57M Imei: 354786xxxxxxxxxxx Unique Number: CBJ007098531745 Connections: AT,MTP Battery Status: 3.87V (44%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.15.20 10:27:14] WorkID: 100789629 |
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
