GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-14-2019, 08:41   #1 (permalink)
Member: 1033866
Sonork: 100.1668276
Thanks Meter: 10
Red face Samsung J600G Patch Problem
Hello PS,
Samsung J600g Patch Done by Chimera but IMEI Status is NG
Chimera Mobile Phone Utility version: 20.49.1355 @ 2019-03-14
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-J600G
Sales Code: INS
Country Code: India
Timezone: Asia/Kolkata
Android Version: 8.0.0 [R16NW] [SDK 26]
Build Date: Fri Jul 13 14:58:37 KST 2018
PDA Version: J600GDXU2ARG7 [july 2018, rev7]
Phone Version: J600GDXU2ARG1 [july 2018, rev1]
CSC Version: J600GODM2ARG7 [july 2018, rev7]
Product Code: INS
HIDSw Version: J600GDXU2ARG7/J600GODM2ARG7/J600GDXU2ARG1/J600GDXU2ARG7
Board Platform: EXYNOS5
Modem Platform: SHANNON315
Serial Number: RZ8K704QMKE
Imei: 35xxxxxxxxxxxxx
Unique Number: CBJ00995DEE2165
Connections: AT,MTP
Battery Status: 4.14V (83%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2018-07-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data...
Checking modem version.
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
Communicating with the server. Be patient! Do NOT disconnect the phone!
Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [03.14.19 13:05:58]
WorkID: 54709376
Old 03-14-2019, 11:16   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 16,670
reply
Hi,
please re.flash your device, after it start again imei repair and patch cert process.
Best regards
Nicole
Originally Posted by prajkumari View Post
Hello PS,
Model: SM-J600G
Sales Code: INS
Country Code: India
Product Code: INS
Connections: AT,MTP
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking modem.
Checking root.
Writing boot image.
Restarting phone.
Reading data...
Succeeded.
WorkID: 54709376
Old 03-14-2019, 16:15   #3 (permalink)
Member: 2377851
Thanks Meter: 18
I Think that J400M/F , J600M Cellphones are in BETA MODE, because i dont see a sucesfull operation with these models using Chimera. I think that you should remove this information with this model until you get a final/sucesfull solution, cuz you are literally playing with our feelings ( lol ).
Old 03-14-2019, 17:11   #4 (permalink)
Member: 1787203
reply
Hi,
we have lot of successfully process on the same devices so it is total not beta.
The process successfully done in this case too, NG status comes from total difference cases.
In a 99% of the cases NG status comes from the wrong sequence of the processes or the lot of started process on the device.
In this case after the re-flash user will get a "clear" device and start again the processes. The correct sequence in each case the Repair imei OR Write cert process and the Patch cert will be the last step.
You can see from lot of post the correct sequence and the repeat of the processes are solved the NG status problem.
Best regards
Nicole
Old 03-14-2019, 17:30   #5 (permalink)
Member: 2377851
Thanks Meter: 18
Originally Posted by Chimera Tool View Post
Hi,
Best regards
Nicole
There should be some tutorials of your own, showing us the whole process.
Can you share with me, the link of theses sucesfull processes with these devices? Havent seem a clear one.
Old 03-14-2019, 21:06   #6 (permalink)
Member: 2554276
How did you make the j600g model root?
Old 03-14-2019, 21:52   #7 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 68
this is just a beta I have tested j400f j400m and j600m all the same result ng there is no signal, I have tried different firmware and the result is the same ng so the chimera team should say what firmware should be used for the effective repair and not have to waste so much time ......
http://forum.gsmhosting.com/vbb/f898...j4-j6-2567430/
Old 03-14-2019, 21:56   #8 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 68
for now for some models we only buy smoke
Old 03-14-2019, 23:17   #9 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 328
yes
no any success report for this models
i guess chimera team working for this problem and also working for other new exinos models patch cert
like a530f a10 m10 and etc
i'm right chimera team?
Old 03-15-2019, 01:19   #10 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 140
Try a permissive boot.img, example, from combinatiin, or find way to make it permissive. The issue is with new selinux style. With a selinux pernissive boot.img, selinux issues are ignored. There are some models which have differences, so some workarounds may be necessary for now.
The Following 2 Users Say Thank You to chavonbravo For This Useful Post:
Old 03-15-2019, 16:10   #11 (permalink)
Member: 2377851
Thanks Meter: 18
Yeah... We only buy smoke.
Hope Chimera will bring a good solution (My Hope on You Guys)
Old 03-16-2019, 18:04   #12 (permalink)
Member: 2483507
Thanks Meter: 81
Hi,
Best regards
Nicole
I cannot see anyone on this model success....
Old 03-18-2019, 14:14   #13 (permalink)
Member: 1787203
reply
Hi,
Naturally here you can find lot of post about unsuccessful processes and other problems, our users are writing here because they faced with some issue.
We can not post here screenshot about the processes because of the GDPR, but you can be sure when the processes result rate low or we find problem with it, the process will be removed immediately. By that case we have 80% successful result rate.
Just read our previously posts, many times when we find problem with one process our team removed it without any problem and we added it again when we were 100% sure the problem solved and the process working correctly.
Best regards
Nicole
Old 10-28-2019, 09:53   #14 (permalink)
Member: 2083965
Thanks Meter: 7
Unhappy
i repair my j600g and successfully patch but after restart my phone the imei status is NG and phone is showing emergency call only
if anyone have solution soo please share
Thanks alot.
Old 10-28-2019, 11:15   #15 (permalink)
Member: 1787203
reply
Hi,
please send us the work id of the patch cert process and we can check your case.
Thank you in advance!
Best regards
Nicole
Thanks alot.
Page generated in 0.43346 seconds with 7 queries
