10-16-2020, 12:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Samsung M10 (M105M) BIT5 Patch Cert Done World First Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-M105M Carrier ID: TPA Sales Code: TPA Country Code: PANAMA Timezone: America/Caracas Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Sat Jul 18 07:28:41 KST 2020 PDA Version: M105MUBS5BTG1 [july 2020, rev1] Phone Version: M105MUBS5BTG1 [july 2020, rev1] CSC Version: M105MOWO5BTG1 [july 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R28XXXXXY Imei: 35566XXXXXXXXXX Battery Status: 3.82V (22%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v00 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.16.20 07:50:39] WorkID: 111431229 |
The Following User Says Thank You to Shensohau For This Useful Post: |
