02-13-2021, 10:57 | #1 (permalink) |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | Samsung S10 5G imei repair done. Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G977N Carrier ID: KTC Sales Code: KTC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Jul 6 17:07:50 KST 2020 PDA Version: G977NKSU4CTG1 [july 2020, rev1] Phone Version: G977NKOU4CTG1 [july 2020, rev1] CSC Version: G977NOKR4CTG1 [july 2020, rev1] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON50005100 Serial Number: R3CM30202NW Imei: 355375100XXXXXX Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-07-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808#(There is you need enter 319712358>774632 and choose usb settings) 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying on port SAMSUNG Mobile USB Serial Port (COM7) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM7) Processing. Be patient! Do NOT disconnect the phone! Current imei: 355375100XXXXXX Repaired imei: 869032030XXXXXX Successfully finished. Patch certificate: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G977N Carrier ID: KTC Sales Code: KTC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Jul 6 17:07:50 KST 2020 PDA Version: G977NKSU4CTG1 [july 2020, rev1] Phone Version: G977NKOU4CTG1 [july 2020, rev1] CSC Version: G977NOKR4CTG1 [july 2020, rev1] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON50005100 Serial Number: R3CM30202NW Imei: 869032030XXXXXX Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. |
02-15-2021, 11:04 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Good day! Thank you for the report, and for the posted log. Hopefully the tool can help you out in your other works. Quote:
01-06-2022, 15:15 | #7 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i have some question so update same thread ==== s10 5g imei was changed patched imei status ok ----- i write original imei from backside imei still ng without patch after 4 to 5 mint imei status become ok butt customer say xyz ------------- yesterday a51 same problem if cert patch imei status become ok after 5 second |
01-06-2022, 17:43 | #8 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i reflash phone with full firmware now imei status NG even after 30 minuts......... i know its work after patch BUTT IF NEED PHONE UNROOTED AND SIM WORK WHAT HAVE TO DO THANKS |
01-07-2022, 10:40 | #9 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear User, You want to use the original IMEI or you have to change it? Because if you change the IMEI you cannot avoid the rooting as you will need the Patch Cert. Best regards Sab Chimera team |
01-07-2022, 14:24 | #10 (permalink) | |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
butt phone is rooted and imei changed before.. i want to get back everything original official if possible | |
The Following 2 Users Say Thank You to chand_gee For This Useful Post: |
