10-22-2020, 13:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | Samsung S10e patch ok but after reboot network disappear but if i reboot recovery its works again plz fix this bug Chimera Mobile Phone Utility version: 26.38.1324 @ 2020-10-22 Printing phone history Patch Certificate 2020/10/21 8:32 AM Repair IMEI 2020/10/21 8:27 AM Repair IMEI 2020/10/21 8:24 AM Repair IMEI 2020/10/20 9:59 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G970F Carrier ID: XFV Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jul 16 19:09:43 KST 2020 PDA Version: G970FXXU8CTG4 [july 2020, rev4] Phone Version: G970FXXU8CTG4 [july 2020, rev4] CSC Version: G970FOXM8CTG4 [july 2020, rev4] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8M30J584Z Imei: 354898762609856 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.22.20 14:00:56] WorkID: 112295902 |
10-22-2020, 14:04 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,744 | reply Hi, Yes that device have to booted up in recovery. Currently we are checking other workaround, with the goal to avoid this method. Quote:
