Samsung S7 SM-G930F IMEI Repair Failed Chimera Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-03-07 Printing phone history SW Change 3/7/2018 10:46:12 AM SW Change 3/7/2018 10:44:22 AM Repair IMEI 3/7/2018 10:38:03 AM Restore / Store backup 3/7/2018 10:36:50 AM Restore / Store backup 3/6/2018 10:35:14 AM [Repair started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: DBT Country Code: Germany Timezone: Asia/Karachi Android Version: 6.0.1 [MMB29K] Build Date: Thu Dec 15 11:30:52 KST 2016 PDA Version: G930FXXU1BPLB [december 2016, revB] Phone Version: G930FXXU1APB6 [february 2016, rev6] CSC Version: G930FDBT1BPH2 [august 2016, rev2] Product Code: XXXXXXXXXXXXXX HIDSw Version: G930FXXU1BPLB/G930FDBT1BPH2/G930FXXU1APB6/G930FXXU1BPLB Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HA12AVPK Imei: 000000000000000 Unique Number: CE091609720D301302 Connections: AT,MTP Battery Status: 4.20V (83%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2016-12-01 Data Encryption State: encrypted Repairing imei... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Repair imei failed. Unable to Repair imei Finished at local time: [03.07.18 15:48:20] WorkID: 34404034 |
reply Dear Sir, device's EFS damaged. First of all you need repair it, when it is done you are able to repair IMEI too. Best regards Nicole Quote:
To fix the damaged security or recover the EFS folder, there are not many boxes that do it. Imei: 000000000000000 You could try it manually following this method: Steps to try to rebuild the EFS folder with a combination file: 1. The first thing is to have our phone with imei in 0000-0000 or Unknown 2. Root, with CFAutoRoot and is done through Odin v.3.12.5 in the AP option and activate in addition to USB Debugging the OEM Unlocking 3. Once the root is done we proceed to install a Root Explorer and access the EFS folder and we will delete all the content except the folders "FactoryApp" and "prov_data" and turn off the phone. 4. The next step will be to flash via Odin with the Factory_Binary (Combine File) of the model to work. 5. Once the Reset is done, press the "IME" button and a keyboard will appear with which we proceed to verify the IMEI with * # 06 # and we will see that our imei is already correct again 6. Proceed to flash with a Stock Rom and this is it, IMEI Recovered and ready to continue working. |
@ Chimera Tool ; taking advantage of the colleague's topic, I would like to know after repair imei of the g930f, the same can upgrade android and factory restore and the patch file does not need to do again. competitor is not possible. legend or truth? |
If you now have a firmware with binary: 2 then you will not be able to repair it until there are new updates. |
after imei repair , upgrade via ota can? factory reset ? other box , not possible will be without signal friend say chimera can do, ota and reset Can anyone confirm? |
Hello could help me friends. I upgraded s930f to android 7.0, can not back to 6.0 is giving sw-rev check fail device 2 binary 1. Help me please |
No, if you do that need repair and patch again... Best Regards Shensohau |
Binary2. Security level 2018 imei repair way??????????? |
Hi, not solution yet... wait until new updates... Quote:
I have a g930f to repair imei with binary 3 some solution? eh tested with z3x and octopus and none lifts it |
