Samsung SM-A336B (A33 5G) (U7) IMEI REPAIR https://www.ozellikleri.net/img/tele...axy-a33-5g.jpg Chimera Mobile Phone Utility version: 37.16.1131 @ 2023-10-04 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A336B Carrier ID: EUX Sales Code: SWC Country Code: Switzerland Timezone: Europe/Istanbul Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Mon Jul 10 19:31:07 KST 2023 PDA Version: A336BXXS7CWG1 [july 2023, rev1] Phone Version: A336BXXS7CWG1 [july 2023, rev1] CSC Version: A336BOXM7CWG1 [july 2023, rev1] Board Platform: UNIVERSAL8825 Modem Platform: SHANNON5308AP Imei: XX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-07-01 Em Did: 200075ED90428011 Repair imei... Operation in progress. Be patient! Do NOT disconnect the phone! Servicing phone. Be patient! Do NOT disconnect the phone! Restarting phone Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Current IMEI: XX Repaired IMEI: XX Current IMEI2: XX Repaired IMEI2: XXX Successfully finished. Finished at local time: [10.04.23 18:43:48] WorkID: 237677531 --------- Chimera Mobile Phone Utility version: 37.16.1131 @ 2023-10-04 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A336B Carrier ID: EUX Sales Code: SWC Country Code: Switzerland Timezone: Europe/Istanbul Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Mon Jul 10 19:31:07 KST 2023 PDA Version: A336BXXS7CWG1 [july 2023, rev1] Phone Version: A336BXXS7CWG1 [july 2023, rev1] CSC Version: A336BOXM7CWG1 [july 2023, rev1] Board Platform: UNIVERSAL8825 Modem Platform: SHANNON5308AP Imei: XX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-07-01 Em Did: 200075ED90428011 Preparing... Servicing phone. Be patient! Do NOT disconnect the phone! Patching certificate... About 10-40 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. If you modify firmware, imei, csc, simlock status, or if *#0011# does not show "IMEI Status: OK", you should repeat the patchcert process. Successfully finished. Finished at local time: [10.04.23 18:50:30] WorkID: 237679130 |
a336e u7 repair imei Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A336E Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Mon Aug 21 19:18:40 +07 2023 PDA Version: A336EDXU7CWH2 [august 2023, rev2] Phone Version: A336EDXU7CWH2 [august 2023, rev2] CSC Version: A336EOJM7CWH2 [august 2023, rev2] Board Platform: UNIVERSAL8825 Modem Platform: SHANNON5308AP Imei: 353475128278485 Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-08-01 Em Did: 2000348FA7528011 Repair imei... Operation in progress. Be patient! Do NOT disconnect the phone! Servicing phone. Be patient! Do NOT disconnect the phone! Restarting phone Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Current IMEI: 353475128278485 Repaired IMEI: 868310032301255 Current IMEI2: 355814218278484 Repaired IMEI2: 868310032303947 Successfully finished. Finished at local time: [11.02.23 15:21:20] WorkID: 241998554;) Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A336E Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Mon Aug 21 19:18:40 +07 2023 PDA Version: A336EDXU7CWH2 [august 2023, rev2] Phone Version: A336EDXU7CWH2 [august 2023, rev2] CSC Version: A336EOJM7CWH2 [august 2023, rev2] Board Platform: UNIVERSAL8825 Modem Platform: SHANNON5308AP Imei: 868310032301255 Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-08-01 Em Did: 2000348FA7528011 Preparing... Servicing phone. Be patient! Do NOT disconnect the phone! Patching certificate... About 10-40 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. If you modify firmware, imei, csc, simlock status, or if *#0011# does not show "IMEI Status: OK", you should repeat the patchcert process. Successfully finished. Finished at local time: [11.02.23 15:26:38] WorkID: 241999768 |
