02-11-2021, 15:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | SC-02M 2019 securty after patch same NG work id Patch Certificate Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SC-02M Carrier ID: DCM Sales Code: DCM Country Code: JP Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Sep 16 17:33:00 KST 2019 PDA Version: SC02MOMU1ASI5 [september 2019, rev5] Phone Version: SC02MOMU1ASI5 [september 2019, rev5] CSC Version: SC02MDCM1ASI5 [september 2019, rev5] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8MA0FEFQY Imei: xxxxxxxxxx Battery Status: 4.25V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-09-01 Preparing... Checking root access. The phone is rooted by: 21.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [02.11.21 18:39:55] WorkID: 124764025 124765356 2020 124764025 2019 |
02-13-2021, 14:49 | #2 (permalink) | |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Quote:
helo chimera team plz risponce thanks | |
02-15-2021, 10:54 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Hi, Please run a Factory Reset on the phone. Then reflash the device. Make sure that you root the phone again with another Root method. Then repeat the IMEI repair and the Patch cert! Quote:
