10-19-2020, 00:33 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | SM-A105F u4 Sucessfull Printing phone history Repair IMEI 15.10.2020 20:02 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105FN Carrier ID: XEF Sales Code: XEF Country Code: France Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jul 9 18:19:55 KST 2020 PDA Version: A105FNXXS4BTG1 [july 2020, rev1] Phone Version: A105FNXXS4BTG1 [july 2020, rev1] CSC Version: A105FNOXM4BTG1 [july 2020, rev1] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: R58MA2PDY3M Imei: 3586 Imei2: 3586 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.16.20 04:05:30] WorkID: 111390499 |
The Following User Says Thank You to loniryan For This Useful Post: |
