07-16-2020, 11:02 | #1 (permalink) |
Crazy Poster Join Date: Apr 2017 Location: PAKISTAN Age: 27
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Sm-a205f u7 imei repair and patch done Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Sales Code: INS Country Code: India Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue May 5 21:52:20 KST 2020 PDA Version: A205FXXS7ATD1 [april 2020, rev1] Phone Version: A205FDDS7ATD1 [april 2020, rev1] CSC Version: A205FODM7ATD3 [april 2020, rev3] Product Code: INS HIDSw Version: A205FXXS7ATD1/A205FODM7ATD3/A205FDDS7ATD1/A205FXXS7ATD1 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RR8M909KHXK Imei: 357463105242860 Unique Number: CBJ000AEDCA7586 Connections: AT,MTP Battery Status: 3.98V (62%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-04-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying to enable diagnostic mode. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Succeeded. Trying on port SAMSUNG Mobile USB Serial Port (COM83) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM83) Processing. Be patient! Do NOT disconnect the phone! Current imei: 35XXXXXXXXXXXX Repaired imei: 35XXXXXXXXXXXX Current imei2: 35XXXXXXXXXXXX Repaired imei2: 35XXXXXXXXXXXX Successfully finished. Finished at local time: [07.16.20 13:57:00] WorkID: 100904345 PATCH Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Sales Code: INS Country Code: India Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue May 5 21:52:20 KST 2020 PDA Version: A205FXXS7ATD1 [april 2020, rev1] Phone Version: A205FDDS7ATD1 [april 2020, rev1] CSC Version: A205FODM7ATD3 [april 2020, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RR8M909KHXK Battery Status: 3.99V (67%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.16.20 14:34:54] WorkID: 100907960 |
The Following User Says Thank You to amirshahzad07 For This Useful Post: |
03-06-2021, 05:45 | #4 (permalink) |
Insane Poster Join Date: Dec 2010 Location: Find Me All Social Platforms
Member: 1469250 Status: Offline Sonork: 100.1662168 Thanks Meter: 75 | Showing OEM Option In Setting! Note: Do Not Connect Internet 1. Goto Settings, Software Update (Turn OFF Update) Go Back To Home Screen & Close Recent Apps! 2. Goto Settings, General, Time/Date, Turn OFF Auto Update & Set Date 11/12 Days Back (Present: 06-03-2021 Set It To 22-02-2021) Go Back Home Screen & Close Recent Apps! 3. Goto Settings, Connect Wifi (Wait 2/3 Mints) Go Back Home Screen & Close Recent Apps 4. Goto Settings, About, Software Information, Tap 7 Times Build Numbers To Show "Developer Option" Go Back Home Screen & Close Recent Apps Wait 3/5 Minutes Then Goto Settings, Developer Option & Check OEM Option? If Success Then Okay! Otherwise Wipe Your Phone & Do Not Connect Internet Then Process from Start...! Hope Will Success! Br. NAsiR_TaNK @KxNTeam @Pak S/W Solutions (WhatsApp Group!) |
