05-06-2021, 06:14 | #1 (permalink) |
Crazy Poster Join Date: Apr 2017 Location: PAKISTAN Age: 27
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Sm-a217f u5 imei repire problem Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A217F Carrier ID: XSG Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jan 14 10:45:04 KST 2021 PDA Version: A217FXXU5BUA2 [january 2021, rev2] Phone Version: A217FXXU5BUA2 [january 2021, rev2] CSC Version: A217FOJM5BUA1 [january 2021, rev1] Product Code: XSG HIDSw Version: A217FXXU5BUA2/A217FOJM5BUA1/A217FXXU5BUA2/A217FXXU5BUA2 Board Platform: UNIVERSAL3830 Modem Platform: SHANNON318 Serial Number: RF8NB05TDKL Imei: 35XXXXXXXXXXXX Imei2: 35XXXXXXXXXXXX Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 2003546EDEDEEE11 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [05.05.21 18:07:54] WorkID: 133333464 |
05-06-2021, 09:49 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, We checked your works and we found out that you already did the process successfully once. What happened after that? Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-06-2021, 10:39 | #3 (permalink) |
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | maybe you check patch cert work id but imei repire always fail patch cert is here WorkID: 133329014 but i want to repire imei first plz fix it all ready try difrent firmware and root mathod |
05-06-2021, 10:56 | #4 (permalink) | |
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Quote:
all i want first repire imei then patch cert i hope you understand plz fix this bug for me | |
05-06-2021, 14:53 | #5 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, Reflash it with the Stock Firmware again. Root it but with another root method. Then check the imei repair. If it is not working, do a factory reset and then repeat the imei repair. Best regards Sab Chimera Team |
05-07-2021, 06:15 | #6 (permalink) | |
i"m all ready flash difrent firmware and reflash and factory reset mathod but sad no luck maybe chimera need another big update for samsung phone again all most 6 month ago no update for samsung no offence <3 | |
05-07-2021, 09:44 | #7 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, We will investigate this process, as we see other users also have issues with it. Our last samsung update was done one and a half months ago for the Android 11. Best regards Sab Chimera Team Quote:
05-26-2021, 16:00 | #9 (permalink) |
Junior Member Join Date: May 2016 Location: Mardan Pakistan
Member: 2566955 Status: Offline Sonork: 1673467 Thanks Meter: 0 | Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-26 Printing phone history Repair IMEI 5/26/2021 2:51 PM Repair IMEI 5/26/2021 1:32 PM Repair IMEI 5/26/2021 1:28 PM Get Info 5/26/2021 1:17 PM Repair IMEI 5/26/2021 1:15 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A217F Carrier ID: XSG Sales Code: SER Country Code: Russia Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jan 14 10:45:04 KST 2021 PDA Version: A217FXXU5BUA2 [january 2021, rev2] Phone Version: A217FXXU5BUA2 [january 2021, rev2] CSC Version: A217FOXM5BUA2 [january 2021, rev2] Product Code: SER HIDSw Version: A217FXXU5BUA2/A217FOXM5BUA2/A217FXXU5BUA2/A217FXXU5BUA2 Board Platform: UNIVERSAL3830 Modem Platform: SHANNON318 Serial Number: RF8N81D85AE Imei: 358590480192085 Imei2: 359714470192082 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 2002E50EA458EE11 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [05.26.21 19:58:54] WorkID: 135671093\ |
05-26-2021, 16:33 | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear mehran26665, WE are working on this case. We do have issues with the posted device recently, but we hope that soon we can fix it. Please try to reflash it and then root it again. Then run the services with the Chimera Tool. Best regards Sab Chimera Team Quote:
05-27-2021, 16:27 | #11 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242372 Status: Offline Sonork: 1658118:Qari Thanks Meter: 5 | A21s U5 ....... Network Type: GSM SIM Status: ABSENT,UNKNOWN Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 200395CE15B0C111 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [05.27.21 20:15:05] WorkID: 135833247 |
05-28-2021, 06:16 | #12 (permalink) | |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | Quote:
PM me, I can help to bypass security and then you can repair and patch cert! | |
05-28-2021, 21:53 | #14 (permalink) |
Freak Poster Join Date: Apr 2012 Location: gsm
Member: 1750690 Status: Offline Thanks Meter: 70 | write same firmware and do root 100% chimera solve here is log Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-24 Printing phone history Repair IMEI 5/21/2021 3:48 PM Repair IMEI 5/19/2021 7:57 PM Repair IMEI 5/17/2021 11:17 PM Repair IMEI 5/17/2021 11:12 PM Repair IMEI 5/17/2021 10:56 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A217F Carrier ID: PAK Sales Code: TGY Country Code: Hong Kong Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Feb 26 15:54:29 KST 2021 PDA Version: A217FZHU5BUB5 [february 2021, rev5] Phone Version: A217FXXU5BUA2 [january 2021, rev2] CSC Version: A217FOZS5BUB5 [february 2021, rev5] Product Code: TGY HIDSw Version: A217FZHU5BUB5/A217FOZS5BUB5/A217FXXU5BUA2/A217FZHU5BUB5 Board Platform: UNIVERSAL3830 Modem Platform: SHANNON318 Serial Number: RF8NC0L05CD Imei: 35xxxxxxxxxxxxxxx Imei2: 35xxxxxxxxxxxxxx Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 200136CE8A29EE11 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35xxxxxxxxxxxxxx Repaired imei: 35xxxxxxxxxxx262 Current imei2: 35xxxxxxxxxxxxx3 Repaired imei2: 35xxxxxxxxxxxx54 Successfully finished. Finished at local time: [05.24.21 13:29:10] WorkID: 135332413 and patch done Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-24 Printing phone history Repair IMEI 5/24/2021 8:26 AM Repair IMEI 5/21/2021 3:48 PM Repair IMEI 5/19/2021 7:57 PM Repair IMEI 5/17/2021 11:17 PM Repair IMEI 5/17/2021 11:12 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A217F Carrier ID: PAK Sales Code: TGY Country Code: Hong Kong Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Feb 26 15:54:29 KST 2021 PDA Version: A217FZHU5BUB5 [february 2021, rev5] Phone Version: A217FXXU5BUA2 [january 2021, rev2] CSC Version: A217FOZS5BUB5 [february 2021, rev5] Product Code: TGY HIDSw Version: A217FZHU5BUB5/A217FOZS5BUB5/A217FXXU5BUA2/A217FZHU5BUB5 Board Platform: UNIVERSAL3830 Modem Platform: SHANNON318 Serial Number: RF8NC0L05CD Imei: 35xxxxxxxxxxxxx62 Imei2: 35xxxxxxxxxxxxx4 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 200136CE8A29EE11 Preparing... Checking root access. The phone is rooted by: fe4981da:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.24.21 13:35:09] WorkID: 135333358 |
The Following User Says Thank You to Universal957 For This Useful Post: |
05-30-2021, 12:07 | #15 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | Quote:
check imei status ng or ok? we did all done but after complete process imei status ng.your feedback will be help full for others. | |
