03-01-2021, 06:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | SM-A305F Imei repair and patch cert done! Samsung A30 U4 bit succesfully repaired. All operation performed by Chimera Tool. Here is logs: Tried many times with EFT,but cannot did root...Chimera did this by one click,yeah! Firmware update started Processing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A305N, Region: KOR, Provider: SINGLE, PDA: A305NKSU4BTJ1 Reading PIT from phone. Trying to Autoroot. Be patient! Do NOT disconnect the phone! Autoroot succeeded. Flashing boot.img Flashing recovery.img Flashing vbmeta.img Flashing dt.img Flashing dtbo.img Flashing system.img Flashing vendor.img Restarting phone. Successfully finished. Repair IMEI: Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305N Carrier ID: LUC Sales Code: LUC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Oct 12 18:23:09 KST 2020 PDA Version: A305NKSU4BTJ1 [october 2020, rev1] Phone Version: A305NKOU4BTJ1 [october 2020, rev1] CSC Version: A305NOKR4BTJ1 [october 2020, rev1] Product Code: LUC HIDSw Version: A305NKSU4BTJ1/A305NOKR4BTJ1/A305NKOU4BTJ1/A305NKSU4BTJ1 Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: R59N403NKNY Imei: 356126105117512 Connections: AT,MTP Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 3561261051XXXXX Repaired imei: 3542110512XXXXX Successfully finished. Patch certificate: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305N Carrier ID: LUC Sales Code: LUC Country Code: KOREA Timezone: Asia/Tashkent Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Oct 12 18:23:09 KST 2020 PDA Version: A305NKSU4BTJ1 [october 2020, rev1] Phone Version: A305NKOU4BTJ1 [october 2020, rev1] CSC Version: A305NOKR4BTJ1 [october 2020, rev1] Product Code: LUC HIDSw Version: A305NKSU4BTJ1/A305NOKR4BTJ1/A305NKOU4BTJ1/A305NKSU4BTJ1 Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: R59N403NKNY Imei: 3542110512XXXXX Connections: AT,MTP Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Best Regards,Deemauz |
The Following User Says Thank You to Dilmurod1999 For This Useful Post: |
03-01-2021, 11:08 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Hello Deemauz, Thank you for the feedback! Good job from you! Best regards Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
