05-16-2022, 14:41 | #1 (permalink) |
Junior Member Join Date: Apr 2016 Location: Buenos Aires - Argentina Age: 45
Member: 2563951 Status: Offline Thanks Meter: 4 | SM-A325M Imei null after patch certificate [Chimera] Best regards. Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325M Carrier ID: ARO Sales Code: UFN Country Code: Argentina Timezone: America/Argentina/Buenos_Aires Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Oct 19 03:50:22 KST 2021 PDA Version: A325MUBU2AUJ4 [october 2021, rev4] Phone Version: A325MUBU2AUJ4 [october 2021, rev4] CSC Version: A325MOWO2AUJ4 [october 2021, rev4] Product Code: UFN HIDSw Version: A325MUBU2AUJ4/A325MOWO2AUJ4/A325MUBU2AUJ4/A325MUBU2AUJ4 Board Platform: MT6768 Modem Platform: MT6765 Serial Number: RF8R60KB44P Imei: 357400060134757 Connections: AT,MTP Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-11-01 Em Did: 20BFA5A831B7FD11 Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.14.22 20:51:21] WorkID: 180195535 |
05-16-2022, 15:07 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear pwrgabe, Thank you for the shared log. We welcome all information regarding the problem. Please try to reflash the phone with a firmware which contains another modem version. After that do the IMEI REPAIR and the PATCH CERT services. Best regards Sab Chimera team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-16-2022, 17:43 | #3 (permalink) |
Member: 2563951 Status: Offline Thanks Meter: 4 | I use other compilation "A325MUBS2AVA1", but 1min after start imei becomes null. You can see baseband in software information, isnt unknow baseband. If reflash and repeat process or make hard reset, result is the same. There is no other build available.Send logs. Best regards. Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A325M Carrier ID: ARO Sales Code: UFN Country Code: Argentina Timezone: America/Argentina/Buenos_Aires Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Jan 7 02:58:51 KST 2022 PDA Version: A325MUBS2AVA1 [january 2022, rev1] Phone Version: A325MUBS2AVA1 [january 2022, rev1] CSC Version: A325MOWO2AUJ4 [october 2021, rev4] Product Code: UFN HIDSw Version: A325MUBS2AVA1/A325MOWO2AUJ4/A325MUBS2AVA1/A325MUBS2AVA1 Board Platform: MT6768 Modem Platform: MT6765 Serial Number: RF8R60KB44P Imei: 357400060134757 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-01-01 Em Did: 20BFA5A831B7FD11 Preparing... Checking boot... Backing up NVDATA and NVRAM partitions... Creating NVDATA backup NVDATA partition can be restored with the "Store/Restore Backup" function in case of any error Creating NVRAM backup NVRAM partition can be restored with the "Store/Restore Backup" function in case of any error Patching certificate... About 20-30 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.16.22 12:52:28] WorkID: 180359589 |
05-17-2022, 09:53 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear pwrgabe, Okay. Thank you for the feedback. It helps our work. However, we think that the problem could come from the Root method. So we are testing that right now. Hopefully, we can update you within a short amount of time. If you face this issue with other devices as well, please post it. Best regards Sab Chimera team Quote:
