01-15-2021, 15:25 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | a520w patch cert done still ng Printing phone history Patch Certificate 1/11/2021 11:06 PM Patch Certificate 1/8/2021 4:21 PM SW Change 1/8/2021 4:20 PM Patch Certificate 1/8/2021 4:06 PM Patch Certificate 1/8/2021 4:03 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520W Sales Code: GLW Country Code: Canada Timezone: Africa/Addis_Ababa Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Jan 30 15:46:46 KST 2020 PDA Version: A520WVLSBCTA1 [january 2020, rev1] Phone Version: A520WVLSBCTA1 [january 2020, rev1] CSC Version: A520WOYABCTA1 [january 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58JA1RZJ9W Imei: 351911108053649 Battery Status: 3.79V (4%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.15.21 06:23:10] WorkID: 122134782 |
01-15-2021, 15:38 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,757 | reply Hello, Thank you for the report. I would recommend to reflash the device with the Stock Firmware. After that you have to do the rooting again. If you can, please use another root method at this time. After that, you have to repeat the Patch Cert service of course. Then the device should be workable! Sab Quote:
