10-19-2020, 00:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | SM-A505f U5 repair and patch succesfull Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Apr 27 13:21:20 KST 2020 PDA Version: A505FDDU5BTE1 [may 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FOJM5BTE3 [may 2020, rev3] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: R58M515LP0L Imei: 357 Imei2: 357 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 3570881 Repaired imei: 359292 Current imei2: 357089 Repaired imei2: 359292 Successfully finished. Finished at local time: [10.17.20 18:48:10] WorkID: 111630072 Chimera Mobile Phone Utility version: 26.33.1031 @ 2020-10-17 Printing phone history Patch Certificate 17.10.2020 15:51 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Apr 27 13:21:20 KST 2020 PDA Version: A505FDDU5BTE1 [may 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FOJM5BTE3 [may 2020, rev3] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: R58M515LP0L Imei: 359 Imei2: 359 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.17.20 18:52:47] WorkID: 111631147 |
10-19-2020, 08:58 | #2 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | is phone restarts after patch ??? |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
10-19-2020, 18:23 | #13 (permalink) | |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | Quote:
Code: Chimera Mobile Phone Utility version: 26.36.1122 @ 2020-10-19 Printing phone history Patch Certificate 2020-mm-19 5:16 PM Patch Certificate 2020-mm-19 5:15 PM Patch Certificate 2020-mm-19 5:00 PM Repair IMEI 2020-mm-19 3:40 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: MID Sales Code: MID Country Code: Iraq Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jun 2 11:00:06 KST 2020 PDA Version: A505FDDS5BTF1 [june 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FOJM5BTE3 [may 2020, rev3] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: RZ8M72PQ48J Imei: 8 Imei2: 86 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.19.20 20:52:20] WorkID: 111887337 | |
10-19-2020, 22:04 | #14 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2499218 Status: Offline Thanks Meter: 44 | Chimera Mobile Phone Utility version: 26.36.1122 @ 2020-10-20 Printing phone history Patch Certificate 10/19/2020 8:28 PM Patch Certificate 10/19/2020 8:24 PM Patch Certificate 10/19/2020 8:18 PM Patch Certificate 10/19/2020 6:59 PM Reboot 10/19/2020 6:52 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Carrier ID: INS Sales Code: INS Country Code: India Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Jun 5 17:03:16 KST 2020 PDA Version: A505FDDU5BTF1 [june 2020, rev1] Phone Version: A505FXXU5BTE1 [may 2020, rev1] CSC Version: A505FODM5BTE4 [may 2020, rev4] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: RZ8M62D8L4T Imei: 351692041542779 Imei2: 351692044571775 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.20.20 00:24:45] WorkID: 111918700 ng network |
10-19-2020, 23:10 | #15 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | Please only use magisk root with magisk manager version 8 and highher...after root connect your set to wifi internet and update your root version and manager version on magisk-menu.... |
The Following 2 Users Say Thank You to loniryan For This Useful Post: |
