Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-20-2019, 10:31   #1 (permalink)
Member: 2742707
Thanks Meter: 140
Sm-a530f (a8-2018) u5 imei & patch cert done but still emergency calls only
Chimera Mobile Phone Utility version: 21.14.1245 @ 2019-05-20
Printing phone history
Repair IMEI
5/19/2019
8:36:52
AM
Rmm Unlock
5/19/2019
8:33:17
AM
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A530F
Sales Code: SER
Country Code: Russia
Timezone: Africa/Johannesburg
Android Version: 9 [PPR1.180610.011] [SDK 28]
Build Date: Mon Apr 29 14:14:52 KST 2019
PDA Version: A530FXXS5CSE1 [may 2019, rev1]
Phone Version: A530FXXS5CSE1 [may 2019, rev1]
CSC Version: A530FOXM5CSE1 [may 2019, rev1]
Product Code: SER
HIDSw Version: A530FXXS5CSE1/A530FOXM5CSE1/A530FXXS5CSE1/A530FXXS5CSE1
Board Platform: EXYNOS5
Modem Platform: SHANNON327
Serial Number: R58K12AY0EX
Imei: 355038090889289
Unique Number: CBJ00B680B240B4
Connections: AT,MTP
Battery Status: 4.32V (97%)
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-05-01
Data Encryption State: unsupported
Repair imei...
Checking modem version.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data. Be patient! Do NOT disconnect the phone!
Repaired IMEI: 350007556557875
If necessary, use the patch cert procedure.
Succeeded.
Successfully finished.
Finished at local time: [05.20.19 10:36:59]
WorkID: 60112609
Patch Certificate
5/20/2019
8:38:13
AM
Repair IMEI
5/19/2019
8:36:52
AM
Rmm Unlock
5/19/2019
8:33:17
AM
Patch certificate started
Model: SM-A530F
Sales Code: SER
Product Code: SER
Imei: 350007556557875
Connections: AT,MTP
Battery Status: 4.22V (99%)
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking current patchcert.
Restarting phone.
Previous patchcert successfully removed.
Checking modem.
Checking root.
The phone is rooted by: XXXX (topjohnwu)
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Reading data...
Restarting phone.
Patching certificate...
After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds.
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Finished at local time: [05.20.19 10:55:36]
WorkID: 60113529
Page generated in 0.09442 seconds with 8 queries
