03-08-2018, 16:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | (G570f) imei Not found and baseband is unknown Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-03-08 Printing phone history SW Change 3/8/2018 2:47:45 PM Repair Device Root Key 3/8/2018 10:51:22 AM Repair Device Root Key 3/8/2018 10:50:54 AM Info 3/8/2018 3:35:30 AM [Get info started]  Unable to detect imei number and baseband version. It seems that the modem does not work or network is unavailable/disabled.  Please reinstall a complete stock firmware and try again! Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: INS Country Code: India Timezone: Europe/London Android Version: 7.0 [NRD90M] Build Date: Thu Sep 28 21:17:28 KST 2017 PDA Version: G570FXXU1BQIA [september 2017, revA] CSC Version: G570FODD1BQJ1 [october 2017, rev1] Board Platform: EXYNOS5 Serial Number: R28J2226RTE Battery Status: 3.86V (55%) Network Type: GSM SIM Status: NOT_READY,NOT_READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-08-01 Data Encryption State: encrypted Finished successfully. Finished at local time: [03.08.18 20:14:16] WorkID: 34473836 |
03-08-2018, 16:28 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Its CPID base phone so if you have original backup can be repair if you have not backup then you lost your phone thats all. | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-08-2018, 17:32 | #3 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 36
Member: 2371500 Status: Online Thanks Meter: 5,828 | hi to retrieve base band flash stock firmware (4 file ROM) if still unknown its HW issue |
The Following User Says Thank You to profkefah For This Useful Post: |
03-08-2018, 17:59 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | No way to fix this phone with cert file because this is cpid phone. You can write other cert file but it will show only emergency calls because it will show cert fail. It can restore only original cert file. Do not waste your time to find a flash or full firmware when the imei is null / null. To diagnose a hardware problem, you must have the phone and your badge in physical form in front of you to be able to comment on that problem. |
03-08-2018, 18:01 | #5 (permalink) | |
Member: 2371500 Status: Online Thanks Meter: 5,828 | Quote:
i meant to restore base band not restore corrupted cert or imei unknown base band is result of sw or hw issue | |
03-08-2018, 18:18 | #6 (permalink) | |
Dear Sir! The problem to solve is to fix the phone so that it works. There is no solution and I uploaded this post with the correct information. The problem is Imei corrupt and there is no solution for this model and if it recovers the baseband but has no signal, then it wants to recover the baseband. The objective of collaborating is to give concrete solutions. If you have a specific solution and you get 100% working from the phone, then your solution will be welcome. | |
The Following 2 Users Say Thank You to gcceleghg For This Useful Post: |
