10-25-2020, 13:32 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | repiar and patch cert j260f u7 done Code: Chimera Mobile Phone Utility version: 26.33.1031 @ 2020-10-17 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Sat Jun 27 16:26:54 KST 2020 PDA Version: J260FXXU7ATF3 [june 2020, rev3] Phone Version: J260FXXU7ATF1 [june 2020, rev1] CSC Version: J260FOJM7ATG1 [july 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8KC0WN61A Imei: 35181 Imei2: 3518 Battery Status: 3.74V (11%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Warranty Bit: 0 Security Patch: 2020-07-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Appropriate serial port is not available. 1. On the dial window, enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Click the Ok on phone display 4. Wait a few seconds until the diag port is initialized 5. Click Ok button Trying to enable diagnostic mode. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Succeeded. Trying on port SAMSUNG Mobile USB Serial Port (COM184) Diag mode available on port SAMSUNG Mobile USB Serial Port (COM184) Processing. Be patient! Do NOT disconnect the phone! Current imei: 351 Repaired imei: 8628 Current imei2: 3518 Repaired imei2: 8628 Successfully finished. Finished at local time: [10.17.20 16:09:05] WorkID: 111595786 patch cert Code: Chimera Mobile Phone Utility version: 26.33.1031 @ 2020-10-17 Printing phone history Repair IMEI 2020-mm-17 12:35 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Sat Jun 27 16:26:54 KST 2020 PDA Version: J260FXXU7ATF3 [june 2020, rev3] Phone Version: J260FXXU7ATF1 [june 2020, rev1] CSC Version: J260FOJM7ATG1 [july 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8KC0WN61A Imei: 8628 Imei2: 86 Battery Status: 3.97V (62%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Warranty Bit: 1 Security Patch: 2020-07-01 Preparing... Checking root access. The phone is rooted by: magisk20.4 Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.17.20 18:51:53] WorkID: 111625135 |
The Following User Says Thank You to gsm-ok For This Useful Post: |
