Sm-g965f - imei ng Hello, I have repair an S9+ IMEI to a new one. after successful operation now EMERGENCY CALL only. And imei is NG. Please give me the procedure. |
You cannot write new imei(You can. but no patch certificate) only write orginal imei for this models (S9, S9+) |
Dear Sir! Could you upload the operation made with chimera to this post? This is very important to be able to give you help. We have successfully process on the device for example with the follow versions: PDA Version: G965NKSU1ARD6 [april 2018, rev6] Phone Version: G965NKOU1ARD5 [april 2018, rev5] CSC Version: G965NOKR1ARD6 [april 2018, rev6] PDA Version: FA80_G965NKSU1ARB7 Best regards |
You must restore original cert/imei. Looks like you wrote cert from another device perhaps, looking at job history. |
Please read careful the log, Patch Cert not supported on the device at the moment. Added Cert Read / Write, Imei Repair For Exynos Models - First in the World Samsung Galaxy A8 (SM-A530F, SM-A530N, SM-A530W, SM-A530N) Samsung Galaxy A8 + (SM-A750F, SM-A750FN, SM-A750G, SM-A750GN, SM-A750N, SM-A730F) Samsung Galaxy S9 (SM-G960F, SM-G960N, SM-G965F, SM-G965N) Samsung Galaxy Note 9 (SM-N960F, SM-N960N) Samsung Galaxy J7 Duo (SM-J720F, SM-J720M) Samsung Galaxy J2 Core (SM-J260M) Used you the original imei of the device? After the IMEI repair re-flashed the device? Patch cert not supported for this model, may be in future update team will make hot solution for some more devices. Write Its original imei no need to patch for original imei. After write original imei, STATUS 100% OK. If it is not Ok then the Imei is blocked. |
This function is intended for restoring the phone's original IMEI https://chimeratool.com/en/models#q=g965f |
Hi, certificate patched is loosed if flashed stock rom later? |
reply Hi, yes, "If a new firmware is used, the patchcert process must be repeated." Best regards Nicole Quote:
