07-12-2021, 15:26 | #1 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Pakistan Age: 24
Member: 2788598 Status: Offline Thanks Meter: 70 | Sm-g985f u7 imei repair & patch cert done !!! SM-G985F U7 (March 2021) Imei repair and patch cert done by great chimera... here is log Chimera Mobile Phone Utility version: 28.99.1322 @ 2021-07-12 Printing phone history Patch Certificate 7/12/2021 12:39 PM Patch Certificate 7/12/2021 12:28 PM Repair IMEI 7/12/2021 12:26 PM Get Info 7/12/2021 11:24 AM Demo Remove 7/12/2021 11:19 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: KSA Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Mar 12 11:03:09 KST 2021 PDA Version: G985FXXU7DUC7 [march 2021, rev7] Phone Version: G985FXXU7AUC7 [march 2021, rev7] CSC Version: G985FOXM7DUC7 [march 2021, rev7] Product Code: PAK HIDSw Version: G985FXXU7DUC7/G985FOXM7DUC7/G985FXXU7AUC7/G985FXXU7DUC7 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58****** Imei: 111111111111119 Connections: AT,MTP Battery Status: 4.36V (100%) Network Type: GSM SIM Status: ABSENT,NOT_READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Em Did: 200BB7F628E34011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 111111111111119 Repaired imei: 359*********** Current imei2: 444444444444446 Repaired imei2: 359*********** Successfully finished. Finished at local time: [07.12.21 19:02:13] WorkID: 141896775 AND PATCH CERT IS : Chimera Mobile Phone Utility version: 28.99.1322 @ 2021-07-12 Printing phone history Repair IMEI 7/12/2021 2:00 PM Patch Certificate 7/12/2021 12:39 PM Patch Certificate 7/12/2021 12:28 PM Repair IMEI 7/12/2021 12:26 PM Get Info 7/12/2021 11:24 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: KSA Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Mar 12 11:03:09 KST 2021 PDA Version: G985FXXU7DUC7 [march 2021, rev7] Phone Version: G985FXXU7AUC7 [march 2021, rev7] CSC Version: G985FOXM7DUC7 [march 2021, rev7] Product Code: PAK HIDSw Version: G985FXXU7DUC7/G985FOXM7DUC7/G985FXXU7AUC7/G985FXXU7DUC7 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58******** Imei: 359************* Connections: AT,MTP Battery Status: 4.30V (99%) Network Type: GSM SIM Status: ABSENT,NOT_READY Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Em Did: 200BB7F628E34011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.12.21 19:03:16] WorkID: 141897168 here is solution i rooted with magisk then write ENG MODEM file by HALABTECH TOOL here is the link: https://mega.nz/file/roQAWLzK#Htxr2x...VtJj8Ybpv4wT_8 File Password is : ( Amar Ali07 GSMHOSTING ) then Just repeat imei repair and patch cert procedure with (Sep 2020 & Oct 2020) method Enjoy Mates |
The Following 3 Users Say Thank You to Amar Ali07 For This Useful Post: |
07-12-2021, 16:17 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,726 | reply Dear Amar, Thank you for the detailed report! Excellent job from you. Best regards Sab Chimera Team Quote:
07-17-2021, 17:36 | #3 (permalink) | |
Junior Member Join Date: Jul 2009
Member: 1068908 Status: Offline Thanks Meter: 5 | Quote:
flash stock u7-root magisk-patch modem with halabtech tool-repair imei failed | |
07-19-2021, 14:22 | #5 (permalink) | |
The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [07.17.21 10:02:20] WorkID: 142673155 | |
07-19-2021, 18:03 | #7 (permalink) | |
log: Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: WWA Sales Code: WWA Country Code: Hungary Timezone: Europe/Bucharest Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Thu Mar 18 09:34:49 KST 2021 PDA Version: G985FXXS7DUC9 [march 2021, rev9] Phone Version: G985FXXU7DUC7 [march 2021, rev7] CSC Version: G985FOXM7DUC7 [march 2021, rev7] Product Code: WWA HIDSw Version: G985FXXS7DUC9/G985FOXM7DUC7/G985FXXU7DUC7/G985FXXS7DUC9 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N Imei: 000000000000000 Connections: AT,MTP Battery Status: 3.84V (33%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-04-01 Em Did: 200A37CED5454011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [07.19.21 10:01:37] WorkID: 142938341 | |
The Following User Says Thank You to ovid1u For This Useful Post: |
07-20-2021, 10:19 | #8 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,726 | reply Thank you for the feedback. The main issue comes from the Security Patch. The patch prevents the method from work. This is not a new issue - our developers are working on the case for a while and we hope that soon we can release some updates regarding to the problem. Best regards Sab Chimera team Quote:
07-24-2021, 15:58 | #9 (permalink) |
Junior Member Join Date: Jan 2007
Member: 425527 Status: Offline Thanks Meter: 0 | Please help me, I am in U6 binary and when i try to flash u6 ENG modem i got this error: please get the approval to use factory binaries is it posible to bypass this error and flash ENG modem? to make patch cert work? thanks |
07-24-2021, 18:14 | #11 (permalink) |
Member: 425527 Status: Offline Thanks Meter: 0 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: WWA Sales Code: PHE Country Code: SPAIN Timezone: Europe/Madrid Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Mar 12 11:03:09 KST 2021 PDA Version: G985FXXU7DUC7 [march 2021, rev7] Phone Version: G985FXXU7DUC7 [march 2021, rev7] CSC Version: G985FOXM7DUC7 [march 2021, rev7] Product Code: PHE HIDSw Version: G985FXXU7DUC7/G985FOXM7DUC7/G985FXXU7DUC7/G985FXXU7DUC7 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N Imei: 35 Connections: AT,MTP Battery Status: 4.28V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-03-01 Em Did: 20088F2D1A954011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.24.21 19:09:26] WorkID: 143511692 i repeated the process, same firmware, same eng modem, all flashed ok but the same result, boot loop. |
07-26-2021, 10:40 | #12 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,726 | reply Dear ESTIMULO, Do the Patch Cert in Airplane mode please. Then repeat the method in Normal mode. Turn off the device for a few minutes and then boot it up again. Best regards Sab Chimera Team Quote:
