06-01-2020, 06:20 | #1 (permalink) |
Crazy Poster Join Date: Apr 2017 Location: PAKISTAN Age: 27
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Sm-j260f bit u5 patch cert done Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: EGY Country Code: Egypt Timezone: Asia/Karachi Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Wed Jan 8 19:21:52 KST 2020 PDA Version: J260FXXS5ATA3 [january 2020, rev3] Phone Version: J260FXXS5ATA1 [january 2020, rev1] CSC Version: J260FOJM5ATA1 [january 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8MA13YX7E Battery Status: 3.71V (5%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Warranty Bit: 1 Security Patch: 2020-01-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [06.01.20 10:18:09] WorkID: 96673294 |
The Following User Says Thank You to amirshahzad07 For This Useful Post: |
