05-10-2018, 09:22 | #1 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | j510fn keep rebooting hello i have j510fn phone its keep rebooting i flash with chimra tool i download latest file but still same and getting hot Extracting firmware... Unzipping firmware: J510FNXXS2BRA2_J510FNDRE2BQL1_J510FNXXU2BQJ3_HOME. tar.md5. Processing firmware... Flashing firmware... Waiting for download mode. Connecting. Reading PIT from phone. File hidden.img.ext4 size is larger than specified in the PIT. File hidden.img.ext4 will be skipped. It is recommended to use a service-provider independent firmware. Checking firmware compatibility. RP SWREV: S1, T1, H1, R1, A2, P1 The firmware version is compatible. Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing hyp.mbn Flashing NON-HLOS.bin Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing cache.img.ext4 Flashing modem.bin Restarting phone. Finished successfully. Finished at local time: [05.10.18 01:10:39] WorkID: 37531524 |
05-11-2018, 15:11 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,027 | reply Hi, when I see from the log you are skipped the hidden.img file (in the same cases it can be the reason of the problem), please try to install firmware where the hidden.img able to flash into the phone or use pit file what able to config the flash (for the biger hidden.img). Best regards Nicole Quote:
