02-17-2021, 06:23 | #1 (permalink) |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | STK-LX1 write imei signature(Cert) done!!! I can't attach test point image because I haven't enough like to post links =))) Here is my simple job logs: Writing certificate... Validating certificate files Validating C:/Users/Dilmurod/Downloads/stk-lx1/STK-LX1_Group_1_Slot_1_8605670415XXXXX. imei. Validating C:/Users/Dilmurod/Downloads/stk-lx1/STK-LX1_Group_1_Slot_2_8605670415XXXXX. imei Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Rebooting phone to USB update mode Rebooting phone to USB update mode Failed to switch to factory mode with the given method. Rebooting into USB update mode again. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The OEMINFO PSID seems to be invalid. Uploading certificate file from C:/Users/Dilmurod/Downloads/stk-lx1/STK-LX1_Group_1_Slot_1_8605670415XXXXX .imei Uploading certificate file from C:/Users/Dilmurod/Downloads/stk-lx1/STK-LX1_Group_1_Slot_2_8605670415XXXXX .imei Finished at local time: [02.13.21 15:48:43] WorkID: 12493XXXX Warning:If your device Kirin 960 based,Do not do any operation with test point,result concrete will "brick".Have a good day!!! |
The Following User Says Thank You to Dilmurod1999 For This Useful Post: |
