![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 46
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,052 | T505 Root fail Please check Chimera Team Code: Chimera Mobile Phone Utility version: 42.39.1322 @ 2025-03-13 Printing phone history Repair Serial 3/13/2025 7:31 AM Remove FMM 3/13/2025 7:29 AM Remove MDM 3/13/2025 7:29 AM Remove FRP 3/13/2025 7:18 AM Rooting... Reading boot partition... Operation failed Finished at local time: [03.13.25 11:17:43] WorkID: 350840133 |
![]() | #2 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,767 | Dear User, Could you try to use a different cable and port? Also, this is only a generic root procedure, so I would highly suggest using our Samsung specific root, by using Autoroot or MAGISK. Regards, ChimeraTeam Quote:
![]() | #3 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,052 | Hello Actually Many Process fail in EDL mode The device has MDM lock which fail also in EDL mode as you can see from Log Above |
![]() | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 25,767 | Dear User, You have the same problem with the MDM removal as well. We can't connect properly to your phone, and disconnects during the procedure. How did you unlock the bootloader if the device is MDM locked? Regards, ChimeraTeam |
