05-25-2022, 21:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | VOG-L29 After try to usb firmware updte dead only connect to com1 Printing phone history Load Factory Fastboot 21/05/2022 12:30 Loading factory fastboot Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Uploading Fastboot... Selected version: kirin980_chimera_1 Uploading data... Uploading data... Uploading data... Uploading data... Rebooting the device to Fastboot mode... Checking if factory challenge needed... Checking if the factory challenge-response succeed... The phone was software bricked by this procedure to make it enter factory mode. To recover from this state you should do a Repair Boot or a Repair Recovery procedure. Also it's possible that the phone boots into recovery mode only: in this case please do an USB firmware update with a suitable firmware. Finished at local time: [05.21.22 13:34:52] WorkID: 181041022 Chimera Mobile Phone Utility version: 32.13.1420 @ 2022-05-22 Gathering information... Device Model: VOG-L29 Current software version: VOG-L29 12.0.0.132(C185E3R3P1) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify fail Android version: 10 Battery state: 3375mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.8 Phone info: NO MAIN VERSION VendorCountry: hw/meafnaf Base version: VOG-LGRP2-OVS 102.0.0.132 Cust version: VOG-L29-CUST 102.0.0.3(C185) Preload version: VOG-L29-PRELOAD 102.0.0.1(C185R3) Finished at local time: [05.22.22 14:19:26] WorkID: 181169164 |
05-26-2022, 09:52 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear Atou, In that case your phone is connected in Factory Mode. To get out of that mode, you can do two things: 1. Load Factory Fastboot 2. Exit factory mode Once you do one of them, your phone will be connected in Fastboot mode to the tool. Now after that, please do the REPAIR RECOVERY and the USB FIRMWARE UPDATE. Best regards Sab Chimera team Quote:
05-26-2022, 11:01 | #3 (permalink) | |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Quote:
or exit factory mode chimera not detected known huawei device when connected | |
05-26-2022, 14:43 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear User, Please run a HARD RESET on the device. Which means press and hold the POWER button while the device is connected to the pc / tool. Hold the button for about 15-20 sec. Then click on the EXIT FACTORY MODE. Also make sure that you reinstall the Huawei drivers (In the chimera tool - settings menu) before you do that! Best regards Sab Chimera team |
05-26-2022, 20:05 | #5 (permalink) | |
05-27-2022, 08:37 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear Atou, That is good. I mean if you see the COM 1 Port. Then the phone is in Factory Mode. So, connect the device to the tool. Try to use another Cable and Port. The Tool will not recognize the device automatically, you have to select the model number from our list. Then you have to get the mentioned two services (exit factory mode, load factory fastboot). If you still do not see it, do the HARD RESET again. You can also connect it with TESTPOINT. Best regards Sab Chimera team |
