08-26-2020, 20:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Vog-l29 stuck in huawei 1.0 Printing phone history Exit Factory Mode 8/26/2020 6:29 PM Exit Factory Mode 8/26/2020 6:26 PM Load Factory Fastboot 8/26/2020 6:14 PM Exit Factory Mode 8/25/2020 4:01 PM Exit Factory Mode 8/25/2020 3:17 PM Loading factory fastboot The procedure has been canceled. Finished at local time: [08.26.20 22:04:37] WorkID: 105267893 |
08-26-2020, 21:17 | #2 (permalink) |
Junior Member Join Date: Jan 2015 Location: Venezuela
Member: 2332647 Status: Offline Sonork: Dzu Thanks Meter: 1 | Quote: Tapatalk |
08-26-2020, 22:14 | #3 (permalink) |
Junior Member Join Date: Nov 2004 Age: 34
Member: 90245 Status: Offline Thanks Meter: 0 | I had the same problem. Solutuon is Load Factory Fastboot, then Get Info to see verison of firmware ( if you don`t remeber it ), download it , Repair Recovery, USB Firmware Update and you are ready |
08-27-2020, 15:11 | #7 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Printing phone history Repair Recovery 8/27/2020 2:07 PM Load Factory Fastboot 8/27/2020 2:02 PM Modify Oeminfo 8/25/2020 3:10 PM Exit Factory Mode 8/25/2020 3:08 PM Load Factory Fastboot 8/25/2020 3:06 PM Loading factory fastboot Rebooting phone to factory mode Changing to factory mode Gathering phone information Failed to determine current firmware version Failed to obtain vendor/country information Processing phone information Current firmware version: unknown (unknown/unknown) @ unknown Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. Uploading Fastboot... Selected version: kirin980_chimera_1 Uploading data Uploading data Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin980_chimera_1 Uploading data Uploading data Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin980_extracted_v190 Uploading data Uploading data Uploading data Rebooting the device to Fastboot mode... Checking if factory challenge needed... The previously uploaded factory fastboot asked for authentication. Please try an another factory fastboot file Failed to authenticate; phone has improved security Finished at local time: [08.27.20 17:10:31] WorkID: 105348200 Gathering information... Hardware version: Ver2.3 Boot info: locked Image check: secure image verify fail Battery state: 0 Key version: huawei_key_v1 Rescue version: rescue0.6 Phone info: (bootloader) main version do not exist in oeminfo! Base version: AI9M02AI Finished at local time: [08.27.20 17:16:23] Last edited by tintome; 08-27-2020 at 15:16. |
08-27-2020, 16:44 | #8 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Thank you. Do you tried to use all the Fastboot packs from the list? Also the device can be booted up in Fastboot mode? As we see you did try the Repair Recovery previously, but the method got cancelled. Quote:
08-28-2020, 09:25 | #10 (permalink) |
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Exactly, what do you want to do on the device? What is the device problem ? As we see you did the load fastboot service successfully twice, then you tried again for 3 times and then the Repair recovery as well (which tell us that you could boot it up in fastboot mode), then you tried an OEM info chage as well. It is not clear for us, what is your goal with the device. Sab |
10-20-2020, 14:52 | #14 (permalink) |
Freak Poster Join Date: Jan 2018
Member: 2796172 Status: Offline Thanks Meter: 42 | I am having the exact same poroblem, after flashing vog-l29 it just goes into error mode, and fastboot mode. No upgrade, no recovery, flashing is not working as it needs update mode, flashing with OTG not working either :/ any ideas? |
10-20-2020, 14:57 | #15 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
check via fastboot mode | |
The Following User Says Thank You to solgeo For This Useful Post: |
