z10 unloking problem - SOLVED z10 stl100-3 flashing ok but when trying to unlock [Direct unlock started.] Phone is in loader mode Updating software. Retrieving necessary files Retrieving necessary files Extracting: qcfm.image.com.qnx.qcfm.radio.qc8960.BB10_3_0.1419 .783508.signed Initializing phone mode Device recognized Flashing file Parsing file Start flashing Flashing has been finished Reconnected Flashing file Parsing file Start flashing Flashing has been finished Waiting for the phone connection. Please un-plug the cable, put in the battery, turn it on, wait for Chimera logo on your phone, re-plug the cable after that red light blinking and doesn't turn on for chimera logo as it said ohone can be work again hen i flash it any solution for unloking? |
reply Dear Sir, could you write me the work id of the job please? Best regards Nicole Chimera Team Quote:
work id 6122771 wait for help thanks in advance |
reply Dear Sir, Please upload an older software version for example 10.2 and after it try again the unlock process. Best Regards Nicole Chimera Team Quote:
any help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! |
reply Hi, Please make sure that Blackberry Blend drivers are downloaded and installed. Second please note that you have to use Windows 7 or higher version, Windows XP has no support for these kind of procedures. Best Regards, ChimeraTool Team Quote:
you seems like you didn't read my problem. i can succesfuly flash the phone with latest software ; the problem is when i try to unlock ; the phone won't turn on after flashing with unloking files ; so it doesn't turn on to get chimera log un continuing the procedure; just five red light. i tried to flash it with lower software like 10.2 and the same problem ; doesn't turn on. |
reply I totally understand your problem, that's why I wrote what I wrote in the answer. If everything is installed on your Windows 7 system, there are some cases when the phone can not be unlocked. Have you tried on other computer too? Best Regards, ChimeraTool Team Quote:
whatever ,i changed the computer now and same problem phone doesn't turn on after flashing with unlok files. |
reply I've sent your a private message please check it. Best Regards, ChimeraTool Team Quote:
same problem here, flash only works with latest software, downgrade not work, direct unlock not work just give red blinking led z10 stl100-3 , see new thread |
Same problem here with Q10. After flashing the unlock files phone does not boot and LED blinks. |
reply Please send me WorkID for the Unlock procedures. Best Regards, ChimeraTool Team Quote:
6147428 6146869 6146828 6146225 6145210 6143936 6142949 |
