10-08-2014, 19:58 | #1 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1799839 Status: Offline Thanks Meter: 5 | box gpg emmc error (solved) |
10-09-2014, 05:52 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | hi, sorry for late answer because must of our supporting members were enjoying the festivals. I think you are running GPG Emmc box first time. Now, Your box will get the license from the server site. Now, 1. disable your antivirus first. 2. Be online (means internet must connect) 3. Now, run the GPG EMMC latest software again. Enjoy! BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
10-11-2014, 07:29 | #4 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Brother, change A to B cable or change computer port. Also try to connect with other computer which has 32 bit windows. Note: windows 64 bit not supported. and let us know with screen short of GPG EMMC connecting windows. BR Dipendra Pathak |
10-12-2014, 05:31 | #6 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
Bro, 1. right click "Unknown Device" and go to "Properties" 2. Click on "Driver" on the top and click on "Update Driver" 3. Choose "Install from a list or specific location (Advance)" and click "Next" 4. click on "Browse" and now go to GPG EMMC installation location and its' driver folder In My computer, the programme installed C;\Program files\GPG EMMC, so I have to go the following location: C:\Program Files\GPG EMEC\driver 5. Now, Click on "Next" then the device founds driver like below: photo uploader 6. Click on "Next" 7. When it ask "GPGemmc.sys" on (Unknown) is needed, then, brouse the same location as above, means: C:\Program Files\GPG EMEC\driver 8. Now Choose "GPGeMMC" sys file and click on "Open" and "OK" respectively. 9. Click on "Finish" 10. Done Still You have Problem, then, remove fidi drievers etc using "DC-Uninstall_Device_V.1001.exe" And install the driver as mentioned above. Good Luck! BR Dipendra Pathak | |
10-21-2014, 13:21 | #7 (permalink) | |
Member: 1799839 Status: Offline Thanks Meter: 5 | Quote:
Hi work was performed She did not answer | |
10-22-2014, 09:17 | #8 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | I don't understand what do you mean? If you have any problem post the screen short of GPG EMMC Connecting windows. Thank you for your understanding. BR Dipendra Pathak |
12-28-2014, 11:03 | #9 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2315400 Status: Offline Thanks Meter: 0 | Hi,I have gpgemmc box,computer not found the box,just first connect it find(FT232 USB UART) i give the driver from(CDM 208.28 WHQL certified) it chnged to port com 3or4,when i run gpgmmc exe (please connect box and run it again, I have win 7 64 bit,32 finally exp. the pc didn't find any unknown device or gpgemmce box(ON DEVICE MANAGER) to give it the driver. plz help. |
