02-05-2014, 11:34 | #16 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
i will try thanks | |
02-06-2014, 06:46 | #18 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
is it work, external supply for this gpg emmc box, if its work no need to create external board i think, please once test and give report, if its work i will buy this, BR, Srinivas Reddy. | |
02-06-2014, 14:13 | #19 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 592531 Status: Offline Sonork: 100.1641625 Thanks Meter: 17 | SAMSUNG N7100 Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.78 0.03 0.64 0.35 0.00 0.00 Power ON : 2.63 1.75 2.54 1.02 1.65 0.01 ------------------------------------------------------------------- eMMC ORC: C0000000 eMMC CID: 0000000000000000,bad code! >>ID check lost! bro i have 2 set note n7100 but same error can you help me?? |
02-10-2014, 15:21 | #21 (permalink) | |
Insane Poster Join Date: Dec 2013 Location: saudi arabiya Age: 31
Member: 2085357 Status: Offline Sonork: 100.1587837 Thanks Meter: 17 | Quote:
how to connet wair 3.3v and VCC | |
02-16-2014, 21:29 | #23 (permalink) |
Freak Poster Join Date: Jul 2010 Location: sialkot pak ,saudiarabia Age: 39
Member: 1350832 Status: Offline Sonork: 100.1627308 Thanks Meter: 25 | bro i9000 bad code error on isp there r 2 pic of that 1 is new 1 is old in old there is posted 3.3 volts on 2 points plz tell wich is the corrct point i have the same board l;ike old |
02-17-2014, 04:25 | #24 (permalink) |
Crazy Poster Join Date: Nov 2010 Location: Kuala Lumpur
Member: 1450649 Status: Offline Thanks Meter: 3 | dear sir, i have problem... please guide me sir... this is my problem sir... i9300 repair no product name Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.09 0.00 2.75 0.00 0.00 0.00 Power ON : 2.80 1.77 3.30 1.55 2.07 0.01 ------------------------------------------------------------------- eMMC ORC: 00000000 eMMC CID: 0000000000000000,bad code! >>ID check lost! tqvm, sir |
02-17-2014, 12:38 | #26 (permalink) |
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Hi, I given image below for how to sold wire with external power supply from gpg emmc jig and i9300 emmc connection. BR, Srinivas Reddy. |
03-06-2014, 04:28 | #28 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2105071 Status: Offline Thanks Meter: 0 | Sir i have tried all those solutions for over the past 72 hrs and nothing works i have tested it on 5 * N7100 3 * I9300 2 * I9100 (dosen't work either isp or jtag) 1 * direct emmc (movinand samsung b503 fo S III ) 1 * I9500 i supplied external current checked soldering over 10 times and every time i get these great message eMMC ORC: 00000000, bad code ! >> Id check lost or another CID error and when trying jtag release power key >> phone dosent respond bro it even cant jtag and isp seems to be a dead everytime |
03-06-2014, 04:44 | #29 (permalink) |
Member: 2105071 Status: Offline Thanks Meter: 0 | another remark when checking pin info at emmc section if you connected extra power supply you get all the pins green(good contact) remove extra supply and pins returns to normal i tried it on the 10+ phones and didn't return any positive responds just get lost every time id check lost, write size lost, erase lost & finally Box get lost !! sir i have spent 199 Grand for this great invention i only ask for some support to how to make use of this device i tried to change vcc 2.4, 2.6, 2.8 i tried putting external voltage source, i tried to write boot size, i changed writing speeds nothing work every time you get lost |
03-06-2014, 07:13 | #30 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Sri Lanka
Member: 815299 Status: Offline Sonork: 100.1623047 Thanks Meter: 133 | Quote:
(no need vcc from gps isp) | |
