GPG eMMC Box Flashing,Imei Repair,Unlock Error,Solutions&Mannuls Here EFS Repair EFS REPAIR MUST USE NORMAL USB CABLE,MAKE SURE PHONE MUST A DOWNLOAD MODE http://www.gsm-hosting.net/GsM-Hosti...b%20cable.jpeg http://www.gsm-hosting.net/GsM-Hosti...PICTUERS/1.png http://www.gsm-hosting.net/GsM-Hosti...PICTUERS/2.png http://www.gsm-hosting.net/GsM-Hosti...PICTUERS/3.png DONT POST HERE THANKS ETC....... IF YOU LIKE MY POST USE "THANKS"BUTTON |
IMEI Repair http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/1.png http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/2.jpg http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/3.png http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/4.png http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/5.png IMEI REPAIR MUST USE USB SERIAL PORT CABLE.NORMAL USB CABLE CANT WORK IT. WHEN USE NORMAL USB CABLE YOU SURELY GOT THIS ERROR http://www.gsm-hosting.net/GsM-Hosti.../3%20ERROR.png |
FLASHING OR FIRMWARE UPDATES 1)SELECT MODEL NUMBER 2)PUT THE PHONE DOWNLOAD MODE 3)CONNECT USB CABLE 4)ARE YOU USING "tar.md5"(SINGLE FILE) 5)SELECT THIS FILE ON PDA AREA THEN FLASH IT http://www.gsm-hosting.net/GsM-Hosti...UERS/3rd/9.png http://www.gsm-hosting.net/GsM-Hosti...ERS/3rd/10.png Dont Killed Your Phone From Jellybean 4.3, it is not possible to downgrade the Android OS version Otherwise Your Phone Will Be DEAD Or Hang Samsung logo. |
https://imagizer.imageshack.us/v2/22...0/801/d82k.jpg http://www.gsm-hosting.net./GsM-Host.../3%20ERROR.PNG WHILE USE THE GPG USB SERIAL PORT CABLE SO MANY USERS FACED THE TESTED MODE ERROR I HAVE THIS CABLE I CHECK THE CABLE WHERE IS THE PROBLEMS I WILL TRY TO CLEAR AND GIVE THE REPAIR DETAILS IN THIS CABLE |
Dear I have this problem :mad: I have I9300 ime null repair efs cabel usb ok ime 0044 Now http://www.gsm-hosting.net/GsM-Hosti...UERS/2ND/1.png but http://www.gsm-hosting.net./GsM-Host.../3%20ERROR.PNG What is the solution :confused::confused: Wait reply :D |
oki do you have any other usb serial port box(so many samsung tool usb serial based) also you use uart cable then try to rebuild |
Urt cbale driver here. FT232R USB UART driver - Download - 4shared - kob aobaob |
I have same problem i9100 imei canot reipre feiled to entere testmode |
settings > about phone if baseband is unkown then you can't repair IMEI you need to flash correct firmware first then when baseband is restored you can fix imei. |
you can use other com device then repair it Quote:
Sir i do it. With direct connect to pc (laptop) box ok and i just test normal usb cable and rooting same devise full ok But conect urt cable coming this error. It dont ditect direct then download driver seprate named FT232R USB URT DRIVER FT232R USB UART driver - Download - 4shared - kob aobaob If This driver is not correct please give me original driver |
just reset efs but some time unknown base band is hardware this phone cant enter test mode but remmber our "GPG USB SERIAL PORT CABLE" have some problems at this time software also show the test mode failed,so you can use other com device repair the phone thats all |
