09-18-2014, 07:42 | #19 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Post the error in screen short of GPG EMMC Connecting windows (Picture format) brother. BR Dipendra Pathak |
11-03-2014, 05:15 | #21 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: Myanmar
Member: 983242 Status: Offline Sonork: 100.1660072:om Thanks Meter: 3 | (gpg emmc please connect box and run it again help me sir. how to fix this error driver also ok i used window 7 11/2/2014 1:40:23 AM >>Connecting... 11/2/2014 1:40:41 AM >>No box found, System isn't on-line 11/2/2014 1:40:41 AM >>------------------------------------------------------ 11/2/2014 1:42:24 AM >>The device has been disconnected. 11/2/2014 1:42:24 AM >>------------------------------------------------------ 11/2/2014 1:42:26 AM >>Connecting... 11/2/2014 1:42:33 AM >>Connecting... 11/2/2014 1:42:44 AM >>No box found, System isn't on-line 11/2/2014 1:42:44 AM >>------------------------------------------------------ 11/2/2014 1:42:51 AM >>No box found, System isn't on-line 11/2/2014 1:42:51 AM >>------------------------------------------------------ 11/2/2014 1:53:55 AM >>The device has been disconnected. 11/2/2014 1:53:55 AM >>------------------------------------------------------ 11/2/2014 10:37:03 AM >>Connecting... 11/2/2014 10:37:09 AM >>No box found, System isn't on-line 11/2/2014 10:37:09 AM >>------------------------------------------------------ 11/2/2014 8:54:30 AM >>Connecting... 11/2/2014 8:54:49 AM >>No box found, System isn't on-line 11/2/2014 8:54:49 AM >>------------------------------------------------------ 11/2/2014 8:55:11 AM >>Connecting... 11/2/2014 8:55:30 AM >>No box found, System isn't on-line 11/2/2014 8:55:30 AM >>------------------------------------------------------ 11/3/2014 12:35:54 AM >>Connecting... 11/3/2014 12:36:01 AM >>No box found, System isn't on-line 11/3/2014 12:36:01 AM >>------------------------------------------------------ 11/3/2014 12:36:55 AM >>Connecting... 11/3/2014 12:37:14 AM >>No box found, System isn't on-line 11/3/2014 12:37:14 AM >>------------------------------------------------------ 11/3/2014 12:37:35 AM >>Connecting... 11/3/2014 12:37:53 AM >>No box found, System isn't on-line 11/3/2014 12:37:53 AM >>------------------------------------------------------ |
11-05-2014, 20:09 | #22 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1134978 Status: Offline Thanks Meter: 3 | same error "please connect box and run it again" hi. i have the same error my box arrived, it work perfectly for two month, now not work "please connect box and run it again" my box serial is 00000101028 can you help me ?? |
03-24-2015, 11:50 | #24 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | same error "please connect box and run it again" this my serial i have same problem :SN:00000100304 can u help me fix the problem ?thanks some times stuck at GET LICENE |
07-02-2015, 11:42 | #26 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Hi all brothers, * if you are running this box first time, then, you have to let us know so that you get the license from our server. * If you are old user who is using 32 bit windows, then, might be problem of driver or might be problem of registry. In case of registry problem. 1. Go to RUN 2. Type "regedit" 3. go to "Hey_current_users" 4. then "Software" 5. "GPG" 6. Right click "GPGeMMC" 7. and delete it. 8. Now connect "GPG EMMC Box" with good internet connection. 9. Problem solved. * BUT, if you are windows 64 bit users, we are not supported yet. Please install 32 bit windows and run the software. * Try other computer if you have problems and still not solve. * Check your internet (Ask your Internet Provider) * Disable Antivirus when you are running the GPG EMMC Software. * Add Exception to GPG EMMC software in your antivirus software. * Change A to B Cable if needed * If you are facing problem, please feel free to connect your reseller. Note: Please post detail information about your box, when you get such problem? Are you using this box first time? What error gives by the software? The main thing is that where is the screen short of GPG EMMC Connecting windows ? Thank you for you understanding. Hope all clear. BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
07-02-2015, 11:55 | #27 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2203827 Status: Offline Thanks Meter: 0 | all of the above described has been done but there is no result , I bought a box at gsmserver prishol boxing I installed software program started 3 times longer writes pototom reconnect and start boxing again win7 32bit |
07-02-2015, 12:34 | #29 (permalink) | |
Member: 2203827 Status: Offline Thanks Meter: 0 | Quote:
here is my serial number 000102172 what to do next | |
