07-07-2015, 06:39 | #31 (permalink) |
Junior Member Join Date: Aug 2004 Age: 41
Member: 79966 Status: Offline Thanks Meter: 0 | this solve my problem. |
07-31-2015, 08:32 | #36 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Please check with new version 1.35 http://forum.gsmhosting.com/vbb/f899...orted-1974378/ BR Dipendra Pathak Last edited by Dipendra Pathak; 07-31-2015 at 08:38. |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
08-01-2015, 02:44 | #37 (permalink) | |
Insane Poster Join Date: Feb 2009 Location: México D.F. Age: 32
Member: 976188 Status: Offline Thanks Meter: 8 | Quote:
Tank you very much. I solved with the update. | |
The Following User Says Thank You to alangersain For This Useful Post: |
11-03-2016, 13:13 | #42 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2638659 Status: Offline Sonork: www.sonork.com Thanks Meter: 1 | same error "please connect box and run it again" this my serial i have same problem :SN:00000100226 can u help me fix the problem ?thanks some times stuck at GET LICENE 3.11.2016 14:16:28 >>Connecting... 3.11.2016 14:16:30 >>SN:00000100226 3.11.2016 14:16:31 >>Get License data... 3.11.2016 14:16:31 >>Connect server... 3.11.2016 14:16:33 >>BOX_100226: Invalid device information. error: 840 |
11-05-2016, 06:04 | #43 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
1.First, Download Latest version from the support: GPGeMMC_v1.35 2. second, disable your antivirus and windows securities and put GPG EMMC software to exception. 3. Third, edit your registry setting: http://forum.gsmhosting.com/vbb/11142431-post26.html 4. Fourth, try other computers 5. Fifth, change your internet service provider or try with other internet service providers. 6. Sixth, Do not use 64 bit winder and higher than windows 8 7. Seventh, If you are first time using box, then, provide us your box serial number so that we will help your box activate through our server and you will get license of the box Good Luck!!! BR Dipendra Pathak (Inside GPG Box and chips) | |
