Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 01-03-2014, 09:20   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
GPGeMMC Error And Solution&Samsung FAQ From Gpg MobileLab(Kerala.India)
BAD POWER SUPPLY OR WRONG&BAD JTAG CONNECTION MAKE THIS ERROR
1)USE FULL CHARGE BATTERY
2)MUST CONNECT UBS CABLE
The Following 6 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-03-2014, 09:24   #2 (permalink)
Member: 351924
WHILE READ OR WRITE THE BOOT FILE YOU GOT THIS ERROR
1)NEED TO HOLD POWER SUPPLY(HOLD WITH 10 SECONDS)
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-03-2014, 09:39   #3 (permalink)
Member: 351924
BAD CLK CONNECTION OR BAD EMMC MAKE THIS ERROR
1)MAKE SURE CLK CONNECTION PROPER OR NOT
CONNECTION PROPER!!!!!!!!!!?
2)CHANGE EMMC
Old 01-03-2014, 09:57   #4 (permalink)
Member: 351924
MANY TECHNICIANS FACED I9300 AND N7100 HANG SAMSUNG LOGO PROBLEM.WHY PHONE SHOW THIS PROBLEMS?
MOSTLY THIS PROBLEMS FIRMWARE(SOFTWARE)AND BAD EMMC(HARDWARE)
HOW TO CHECK IF PROBLEM HARDWARE OR SOFTWARE?
HARDWARE PROBLEM HAND SETS CANT FLASHED VIA ODIN OR SUPP
ORTED TOOLS.WHEN WE TRY THE FLASH WITH PIT SHOW ERROR.
WITHOUT FLASH YOU EASY TO FIND PROBLEM HARDWARE OR SOFTWARE
JUST PUT THE PHONE DOWNLOAD MODE(ODIN MODE)
CHECK PRODUCT NAME NULL OR NOT.ALSO CHECK CUSTOM BINNARY DOWNLOAD COUNT YES OR NO
PRODUCT NAME NULL?!!!!!ALSO CUSTOM BINNARY DOWNLOAD NO
PROBLEM GO TO HARDWARE,BAD EMMC
THIS CAUSE SOME TIMES SOLVED AFTER WRITE THE FULL DUMP FILE BUT NO MORE HOPE!!!!!!!!
PRODUCT NAME NULL SECOND PROBLEM
BOOT DAMAGED PHONES AFTER BOOT REPAIR PRODUCT NAME ALSO NULL
BUT THIS TIME YOU ALSO CHECK THE CUSTOM DOWNLAOD BINARY COUNT LIKE THIS
PRODUCT NAME:
CUSTOM DOWNLAOD BINARY:2564566545
THIS PHONE EASY TO FLASH WITH ANY SOFTWARE
WITH PIT AND WITHOUT PIT.
AFTER THE FLASH PRODUCT CODE WILL BACK IF STILL SAME PROBLEMS YOU TRY TO RESET EFS THEN CHECK,REMMBER AFTER THE EFS RESET IMEI IS GONE MAKE SURE BEFOR RESET EFS IMEI REBUILD SUPPORTED WITH YOUR TOOLS
The Following 22 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-04-2014, 13:08   #5 (permalink)
Member: 351924
Information About IMEI NULL&BASE BAND UNKNOWN
Two Types Of Imei Null And Base Band Unknown Problems With Samsung Phones
One Is Software And Second Is Hardware
Software:When Lost The Efs Data Phone Show Imei Null And Base Band Unknown
What Is Efs?
Encrypting File System
Efs Inside Nvm Data,Imei,Base Band Data,Wifi And Bluetooth Systems Etc........
How To Damaged Efs Data?
When We Make Wrong Flashing,While Flashing Used Wrong Pit File,Downgrading Etc........
Wrong Flash:Wrong Model Flash File Use To Flash
This Time Phone Boot Going To Damaged(Hard Bricks),Some Time Phone Hanging Samsung Logo(Soft Bricks) Etc......
Soft Bricks Phone Flashed Again With Correct Files Phone Will Alive But Efs Surely Damaged
Hard Bricks Phone Need Repair Boot With Jtag
What Is PIT?
Partition Index Table
Wrong Pit:Wrong Pit Means Every Samsung Phones Used Internal Memory(EMMC),When We Used Re-Partition Option While Flashing,We Used Unsupported Pit Emmc Partition Will Be Damaged Also Damaged Efs
How To Repair Efs?
3 Way To Repair Efs
1st Is Via Adb Mode Like(z3x)
2nd Is Download Mode Like(spt,bst Dongle,octopus etc..)
3rd Is Via Jtag(GPG eMMC,easy jtag etc..)
I Think Efs Repair Good For Via Download Mode.
Just Reset Or Rewrite Suitable Efs.
Now Phone Efs Is Repaired Sucessfully
But Now Imei And Serial Number Damaged
Repair Imei And Serial Supported Box
After Reset Or Rewrite Efs Phone Imei Null And Base Band Unknown?????
Problem Surely Hardware Fault.
But Onething 1st And 2nd Way Not Sucessfully Repaired Efs We Also Try To Write Efs With Jtag
Some Times(Not 100% Sure)Repaired Efs Data
Still Imei Null And Base Band Unknown?????
100% Sure Cause Is Hardware
Hardware:-Mostly Damaged RF-transceiver-IC
But Remmmber You Must Check Usb Port Some Times Bad Usb Also Make This Problems
The Following 29 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-17-2014, 10:42   #6 (permalink)
Member: 351924
HOW TO CHECK EMMC BAD OR NOT WITH GPGeMMC Box?
CONNECT PHONE WITH eMMC Box Then Use Read Info Button
Look the Info log(LIKE THE PICTURE)
PRODUCT NAME IS --------------- Blank Problem With BAD eMMC
The Following 7 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-27-2014, 08:50   #7 (permalink)
Member: 351924
While erase emmc chip you got this error?
WHILE ERASE EMMC CHIP YOU GOT THIS ERROR?
YES PROBLEM EMMC BAD SECTOR
WITHOUT CHANGE EMMC IC CANT SOLVED THE PROBLEMS
Old 02-03-2014, 10:28   #8 (permalink)
Member: 351924
What Is "KNOK"?
KNOX provides a "private space" on a KNOX equipped mobile device where the
customer can store pictures, applications etc.
It will allow only the authorized user (i.e. the customer) to access the KNOX area on
the device as a password is required to access the KNOX area on the device.
To protect the information held within the KNOX area, if the device is rooted, the
device will set its KNOX status, called "KNOX WARRANTY VOID", to 0x1 and disable
KNOX permanently so that nobody can access to the space anymore.
It is not possible to "reset" or "reactivate" KNOX when the "KNOX WARRANTY VOID"
bit is set to 0x1. When the device has been rooted, only by replacing the PBA (as an
Out-Of-Warranty repair action) can the customer be able to use KNOX feature..
how to check KNOX WARRANTY VOID status
1) Enter Download Mode on the device.
- Press Volume down key + Home key + Power key to enter Download Mode.
- Press Volume up key to enter Odin mode.
2) Check KNOX WARRANTY VOID.
- If KNOX WARRANTY VOID is 0x1, It means the phone has been rooted and
KNOX has been "disabled".
Once it is set, it is not possible to rest the status to 0x0 and if the device were to be
returned to the customer with the "original" rooted board then the customer would not
be able to use KNOX.
If the device KNOX WARRANTY VOID status is set to 0x1, then the PBA
replacement of the device is an OUT OF WARRANTY repair.
Dont Killed Your Phone
From Jellybean 4.3, it is not possible to downgrade the Android OS version Otherwise Your Phone Will Be DEAD Or Hang Samsung logo.
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-11-2014, 14:23   #9 (permalink)
Member: 351924
>>Chip information acquisition in error, please check!
Erasing...
Device Ready...
Device Ready...OK!
ID check...
Level (envy) : VCC V18 VCCQ D0 CMD CLK
Pullup : 0.57 0.02 0.04 0.01 0.00 0.00
Power ON : 2.63 1.76 2.52 1.76 1.83 0.01
eMMC ORC: C0FF8080
eMMC CID: 15010056545530304DF1ACA427398F
eMMC CSD: D02701320F5903FFF6DBFFFF8E4040
ID check: 00010015
Product name: VTU00M
User partition size: 146DBFF9200 ( 1338815M / 1307.436G), 1403850297856 Bytes
Boot partition size: 0x10E0000 ( 16.8M )
RPMB partition size: 0x1D20000 ( 29.1M )
ID check...OK!
SAMSUNG N7100(Note2)WHILE ERASING OR WRITING YOU GOT THE ERROR FROM GPG eMMC SOFTWARE?!!!!?
PROBLEMS WITH "DATO"CONNECTION
LOOK THE PICTURE YELLOW CONNECTION IS RIGHT WHEN WE SOLDRING COPPER WIRE SHOT ALSO RED MARKED AREA THATS WHY WE GOT THE ERROR
The Following 14 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 03-13-2014, 07:03   #10 (permalink)
Member: 351924
SAMSUNG I9300,N7100 Etc..AFTER REPAIR THE BOOT AND FLASHING STILL SAMSUNG LOGO?
SAMSUNG I9300,N7100 Etc..AFTER REPAIR THE BOOT AND FLASHING STILL SAMSUNG LOGO AND RESTARTING?
STEP1-PUT THE PHONE RECOVERY MODE
RECOVERY MODE PHONE SHOW THIS EFS ERROR?
(RED MARKED)
STEP2-PUT THE PHONE DOWNLOAD MODE
OPEN GPG EMMC TOOL-ANDROID
SELECT MODEL
CONNECT PHONE CHECK MODEM PORT NUMBER
SAME PORT NUMBER SELECT TO SOFTWARE
THEN USE EFS REPAIR OPTION
AFTER REPAIR EFS PHONE WILL TRUN ON NORMALY
Page generated in 0.20956 seconds with 8 queries
