Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 03-10-2016, 01:32   #1 (permalink)
Member: 2172855
help emmc gpg emmc
Hello every body
I dont use the gpgemmc to repair cell phones but rather the use to recovery data or i try.
I buy to the gpg ft 232 and bga 169 e socket to read the memories but in this 2 months i cant read any emmc
every time i try to read a memory dont matter the brad the gpg emmc say loose contact
I am try to attach images of how i have connected the gpgemmc and i pirnt screen, but i can attch this files
clarified the memory i clean very well before i try to read
i am very greatfull if any one can help me
thanks very much
Old 03-10-2016, 09:52   #2 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,191
Hello Bro,
As everybody knows Jtag and EMMC operation is little bit hard then flashing mobile. Need specific technique and talent! And read manual that is found in sticky thread!!
Where did you post screen short and logs within this period with more information about mobile condition and the process that you have followed? We are not Almighty to find the task that you are feeling inside your heart :P ............. . As you have told a serious lie that you have tried many times but I did not see any screen shorts, logs etc except 2 total post you have been created with this id till March 10, 2016.
Dipendra Pathak
Old 03-10-2016, 22:13   #3 (permalink)
Member: 2172855
Hello mr. Dipendra Pathak, thanks for your answer. These are my first posts as you can see. Sorry if I didn t explain myself correctly on my last post.
I am trying to read directly from the emmc chip because the phone (a galaxy s4 mini ) is severely physically damaged.
The emmc model is a sandisk sdin7du2 8GB
i have checked all voltages of gpg ft232 board and they are ok. Before reading I have removed all excess of tin and cleaned the chip pads very well with alcohol.
The soft detect all connection in green so I guess that ic is correctly placed.
This is the log generated by the gpgemmc when i try to read the emmc memory
Connecting...
SN:00000102289
Get License data...
Verify Liecnse data...
Version:V3.2
Device Ready...OK!
Reading...
Pin Check up...
>>Loose contact
Is possible this is a problem of pullup, i need weld a resistor to do pullup?
Is possible sometihng in the utility i dont setting?
Thanks to answer
i still trying to uploads the photos
Old 03-11-2016, 05:52   #4 (permalink)
Micro Mind's Avatar
Member: 2187058
Thanks Meter: 41
Originally Posted by alemmat View Post
Reading...
Pin Check up...
>>Loose contact
Thanks to answer
Well friend, seems you are using GPG EMMC version 1. if so, you need to use GPG EMMC Power Adapter for it that gives more power for Reading your Chip and this adapter is free of cost which you will get at the time of buying Box. OR, you forget to join external power supply for GPG Emmc. Am I right ?
Well, Both EMMC Boxes are same but Version 1 box need to join EMMC adapter with it where as Version 2 has inbuilt so can do operation directly.
Micro Mind
Old 03-21-2016, 12:40   #5 (permalink)
Member: 1201302
Thanks Meter: 3
how to dead boot repair samsung g531f please solucation
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12359 seconds with 7 queries
