07-26-2015, 17:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 530783 Status: Offline Thanks Meter: 12 | Help with HUAWEI H60-L2 BRICKED The state of the phone is simply that I can get into rescue mode fasboot mode or mode but this mode does nothing or the computer detects nothing. With fastboot I managed to flash the boot.img, system.img ... but there are many other partition and I can not deny me that is the fastboot partition (fastboot.img) will not let me ... I see logical because it is in use and protection ... Anyway, I wonder if riff jtag can support or add support ..? As I can find out? Here I put the 2 images of my problem. I want to make clear that allows me to flash everything but does nothing. Flashing mode for sdcard does not work for some reason. |
07-26-2015, 21:53 | #4 (permalink) |
Member: 530783 Status: Offline Thanks Meter: 12 | If flash was broken when I would not charge anything but fastboot load alone. The phone worked smoothly to update and put that Beta was blocked and I had to turn and never normally well lit if I had to charge the emmc as I recorded the boot. IMG or fastboot. IMG? To do that I need a JTAG compatible with the emmc? |
07-27-2015, 01:13 | #5 (permalink) | |
Junior Member Join Date: Aug 2011
Member: 1637887 Status: Offline Thanks Meter: 2 | Quote:
07-27-2015, 03:12 | #6 (permalink) |
Freak Poster Join Date: May 2014 Location: In the Chip Level
Member: 2187058 Status: Offline Thanks Meter: 41 | before you try with Jtag/EMMC, I suggest you, try with ZZ key http://forum.gsmhosting.com/vbb/f717/ WBR Micro Mind |
07-28-2015, 18:02 | #8 (permalink) | |
Member: 530783 Status: Offline Thanks Meter: 12 | Quote:
