12-09-2016, 11:18 | #1 (permalink) |
Registered User Join Date: Jan 2009 Location: france
Member: 953264 Status: Offline Thanks Meter: 1 | GPG EMMC no work I just bought this box but it does not work. I installed the program, everything goes well, But when I connect a device to ISP or JTAG, it is not detected. When i messure the vcc, 3.3v or 1.8v power supplies, there is nothing. if i try the same device with riff box, all is ok, i connect it with the same wires ? |
12-11-2016, 05:23 | #2 (permalink) | |
No Life Poster Join Date: Apr 2015
Member: 2385015 Status: Offline Thanks Meter: 884 | Quote:
Kindly post here screen shot of error. Br, GPGTeam | |
12-16-2016, 09:37 | #3 (permalink) |
Member: 953264 Status: Offline Thanks Meter: 1 | Hi, thank you for your response, sorry but i can't post screen shots, when i want to attach screen shot i have an error message "upload of file failed", i try different files format (jpg, png...) with respect of the size limit and i try links of uploaded screen shots but always the same error message. can you give me an email adress and i will send you the screenshots. thank you |
12-16-2016, 14:04 | #4 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
hi there! you can create your account for picture uploading https://postimg.org/ and then you can attach picture link over here. You can also give information about windows you are running in your system since we do not support 64 bit windows. And please do not forget to mention your box serial number too. Most of the problems and solutions are found in sticky section. You can check there and follow as mentioned. BR Dipendra Pathak | |
12-19-2016, 12:10 | #5 (permalink) |
Member: 953264 Status: Offline Thanks Meter: 1 | hi, thank you for your response, i already have an account but always the same error message (upload file failed). and i try to post uploaded pictures with your link but i can't post links because i don't have 10 posts for the moment. ok no problem: this is the log in the soft windows: Read Info... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 0.04 0.00 0.00 0.01 0.00 0.00 1.8 Low : 0.04 0.00 0.00 0.00 0.00 0.00 1.8 High : 0.04 0.00 0.00 0.00 0.00 0.00 ... 2.5 Pullup: 0.04 0.00 0.00 0.00 0.00 0.00 2.5 Low : 0.04 0.00 0.00 0.00 0.00 0.00 2.5 High : 0.04 0.00 0.00 0.00 0.00 0.00 ... 3.3 Pullup: 0.04 0.00 0.00 0.00 0.00 0.00 3.3 Low : 0.04 0.00 0.00 0.00 0.00 0.01 3.3 High : 0.04 0.00 0.00 0.00 0.01 0.00 ... Power On : 0.04 0.00 0.00 0.00 0.01 0.01 Set Low : 0.04 0.00 0.00 0.00 0.01 0.00 Set High: 0.04 0.00 0.00 0.00 0.01 0.00 ... Work Voltage: 0.04 0.00 0.00 0.00 0.00 0.00 --------------------------------------------------- eMMC ORC: 00000000 FF eMMC CID: 0000000000000000,bad code! Please check connections. >>ID check lost! i try with an i9300, with an N8000. I have the same error. but i connect the devices correctly and i test them with the riff box, all is ok. (with the same wires) just desold on the epg isp pcb and resold in riff. after i try an i9100 in jtag with GPG easy jig, it was not detected, i try it in riff box with the same easy jig all was ok. 1) when i measure the power (VCC, 3V, 1.8V) on the isp pcb, i already have nothing. 2) just the red led lighting, the green led was never lighting, is it normal ? |
12-19-2016, 23:39 | #7 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | GPG eMMC got two socket at back of BOX - USB B (for communication channel) and miniUSB (for power supply channel) - does you got connected both ??? |
12-22-2016, 05:34 | #9 (permalink) |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Some PC gives less power to USB Devices and boxes. If you do not have good Power supply, this kind of problem presists. Second, you need to give USB power or battery power depending to the device while you are doing operation to cellphones. Thirdly, you need less wire between device and cellphone. So think about this too. WBR Diosa |
