SPECIAL REQUEST TO Faisal_Computer, please help me. HI Faisal_Computer, I love the way you attend to our problem(s), you always to your time to give detailed explanation. i have this problem, i bought a GPG eMMC box online from ipmart but i have this issue of connecting the box with the computer. any time i tried i get this error reply "please connect box and run it again". i have tried all the solution given on the forum but i am still facing the same issue. i even bought a new system which i partitioned to run windows 7 and windows xp (32 bit) it still having the same problem. the serial no.000-102-366. please i do need your help. i know i should have posted the screen-shot but its failing to upload, pls help me, thanks. |
Gpg emmc works with windows xp...any way no one will help you this is bad forum and bad device Sent from my SM-A700FD using Tapatalk |
First of all this is not a bad forum. The problem instead is that this productive not supported. Anyway, gpgemmc works on win x32 as well. Cheers X4ce |
Hello, Please check your Drivers, usb cable, change system and use windows xp Br Faisal_Computer |
bro pls help me http://forum.gsmhosting.com/vbb/f899...pport-1956995/ |
i have done as you suggested but still the same result, "cant connect, try again. please can you check from your server? |
can we connect on whatsapp? |
if you check all and still getting error then ask your reseller to change it under warranty Br Faisal_Computer |
