Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 12-02-2014, 07:31   #1 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Actions PAD Product Tools
Actions PAD Product Tools (Developer Editions)
Actions Semi ATM7029 Quad-core ARM CPU devices
1.01.02 http://yadi.sk/d/wn0y5BdtFmQy9 2012-12-25? (Use newer versions for Ainol firmwares)
1.02.02 http://yadi.sk/d/Xf5NVryz998nC 2013-01-08? (Hero 4 nuclear upgrade tool)
1.02.03 http://yadi.sk/d/GFpAmhs39QZ67 2013-01-28?
1.02.04 http://yadi.sk/d/Q77kNQRx5py4n 2013-02-27?
1.04.01 http://yadi.sk/d/mzPzjx8x98vWv 2013-07-05?
1.05.02 http://yadi.sk/d/KrQo018cDYkqw 2013-11-25 (automatic updates)
1.06.01 http://yadi.sk/d/RFV5MC7SHuhht (test version. Install an older version, or just its drivers to use.)
1.06.02 http://yadi.sk/d/BB67kma9JaUYY 2014-02-25
1.07.02 http://yadi.sk/d/5VDeBWigMwt9X 2014-04-22
v1.07.02 2014-04-22 1) Support BOX Solutions
v1.06.02 2014-02-25 1) Solve the bugs 2) Support compound firmware PRODUCTION and FLASH_ERASE forced to selected Hidden partitions settings All partitions will be programmed onto the device HDCP-KEY programmed together with the firmware only Support signed firmware verification (need the matched public key) Support making mass production card 3) Compatible the sparse firmware and images
v1.05.02 2013-11-25 1) Distinguish the basic and advanced settings 2) Match the partition images in the firmware directory automatically 3) Show the basic settings by default PRODUCTION and FLASH_ERASE are selected by default in advanced settings 4) Support the signed firmware Report error while the firmware is incomplete (missing public key or the signature file) Add verification process while matching the partition image Do not programmed if the firmware is incomplete 5) Upgrade self online 6) Update the Logo and help documentation
The Following 5 Users Say Thank You to dr_moosavi For This Useful Post:
Old 12-02-2014, 07:32   #2 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
For non-developers? (Better use a Developer Edition)
End User Upgrade V1.01
http://yadi.sk/d/VxJwKz95FmQ2t
(if it says "Nothing found" just reload the download page)
The Following 3 Users Say Thank You to dr_moosavi For This Useful Post:
Old 12-02-2014, 07:35   #3 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Actions PAD Firmware Modify Tools
Some Actions' programs I found from Baidu shares during the holidays.
There is many vendors who (unlike Ainol) share these tools there.
When Ainol released the source code, "小二黑, Xiao Erhei"
said that they have some plans to release some more stuff
(like this?) but I've heard nothing about it since then.
With "Pad Firmware Modify Tool" one can do the same things
(and more) that some of my packages do. For example it enables
re-partitioning like the partition patchers and the "Liberator" tool
(although they are lighter/more flexible).
And it also makes boot logo editing package obsolete now...
(when editing Actions' boot logos that is)
For boot.img editing one still might have to use something like my uImage un/repacker.
Anyway, it's a nice tool for stock ROM modders, etc...
Download
V1.01 http://yadi.sk/d/d6CAgFrMFmKEK
V1.02 http://yadi.sk/d/YB8YbVh8GaZCu
V1.03 http://yadi.sk/d/xh90XgBhFmKhA
V1.04 http://yadi.sk/d/kwsfJuypFmKv3
V1.05 http://yadi.sk/d/U1rlJxJIFmKx5
V1.06 http://yadi.sk/d/b82atoUeFmKyk
V2.00 http://yadi.sk/d/JniKWv4QHuhiK (test version)
V1.07 http://yadi.sk/d/yymo17HxJaUZH (automatic updates)
V1.08 http://yadi.sk/d/EzayZ6fRMwmq2
V1.10 http://yadi.sk/d/McQKDNCZYjbQ8 2014-08-08
V1.12 http://yadi.sk/d/QY757mmrbg2ku 2014-09-15
V1.13 2014-10-08
Old 12-02-2014, 07:36   #4 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Other tools from Actions
Pad Image Maker Tool
Make vendor partition images with your own bloatware easily.
V1.01 http://yadi.sk/d/4ofK51BaFmYdT
V1.02 http://yadi.sk/d/UbKHU6mmMwzBs
More tools will be here...
Old 12-02-2014, 07:37   #5 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Actions ATM7029 Hardware Check Tool
Test that it isn't some hardware problem. Needs adfu (product tool) drivers installed.
Download ATM7029 v1.0: http://yadi.sk/d/zTUeOyJ0Ge3ET
Download ATM702X v1.2: http://yadi.sk/d/E7klzRB0KA7W8
Download ATM702X v1.3: http://yadi.sk/d/Ov6gVVawMx2BL
Questions? --> Guide in English, Google translated
Procedure :
1 electrical hardware devices ADFU let into the state , connect the USB to the PC side . If you have already installed the ADFU drive the properties shown below , if the display device or other property can not be identified , reinstall ADFU drive correctly.
2 Double-click on the main folder ATM7029_hardware_tools.exe, open the test interface is as follows :
Test item selection area
Green indicates normal ADFU devices connected
Red means no device is connected to normal ADFU
Button to start the test
Check the items needed to test , the test is as follows :
(1) PMU_initial: The main control on the PMU chip configuration items , configuration master , DDR and SD card required power . If this does not pass , please focus on examination of the PMU 24M clock and SPI interface is OK. The option is mandatory .
(2) DDR_32bit_scan: scan 32bit bit wide DDR data and address lines of the interface. The right to return to full A, an error is returned full 5 0-3 last bit indicates byte0-3 returns an error , return 4 shows the address error, return 5 represents initialization failed. Below shows , which means that the DDR byte1 error.
(3) NAND_CE1 / 2 / / 3/0: NAND flash interface to scan items. According to the actual hardware configuration, select the corresponding CE items. CE is usually double check CE1, CE2, four CE , then the whole hook. Right will return all A, and flash the ID information.
(4) SD_card: The T card is used to detect connectivity interfaces , make sure T card is inserted properly .
(5) Audio: The test is the master data lost through an audio interface to PMU chip, while the output sine wave audio signal through headphones and speaker, can be used to detect abnormal audio path.
(6) HDMI: The test will output an image to the TV , make sure the HDMI cable connected properly .
4 Click the Start button to start the test .
The Following 2 Users Say Thank You to dr_moosavi For This Useful Post:
Old 12-02-2014, 07:41   #6 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
PCBA Test Tool (misc.img version)
A tool to help mass testing. Little or no use otherwise. (Just wanted to see how it works...)
Modified for Crystal 2. To use it, flash it to the misc partition. (just it, no erase nor formatting)
Unplug charger/usb before starting. To remove, just flash the original misc.img back.
To use it in another tablet, copy boot.img, dk44k_2ch_20s.wav, pcba.conf, modules.sh
and the lib folder to its misc and make the necessary changes.
Tests: memory, flash, wifi, gsensor, camera(s), bluetooth, clock, vibrator,
sdcard, OTG, USB, HDMI, headphones, buttons, touch, sound and mic.
An image with bad translations included. (bluetooth and HDMI not in it)
Download: http://yadi.sk/d/ANWlpQlZGmiTt
Old 12-02-2014, 07:42   #7 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Pad Card Writer Tool V1.01
Make bootable SD cards. Don't ask me how
Download: http://yadi.sk/d/qafCqqsYGqBys
Chinese instructions: http://yadi.sk/i/9OVS4SGAVmHw2
SD card package for Hero2: http://yadi.sk/d/FGvUiJ4CVoTgV
For some reason erasing flash didn't work for me. It might be that the boot device must be changed to SD card??
In some package it was done in afi.cfg like this (haven't tested)
// Boot Device
// 0x00 - NAND
// 0x20 - SD0
// 0x21 - SD1
// 0x22 - SD2
INF_AFI_DEF_BYTE = 0x08,0x20; // sd0
Old 12-02-2014, 07:42   #8 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
More Actions' Test apps
They are in Chinese so I don't know much about them.
These can be run as normal apps in any model, starting is just a bit different.
Some of them might be already installed by default.
ActionsPcbaTest.apk - same as the previous misc.img version
ActionsProductLineTest.apk - similar, but less automatic, maybe more control
ActionsAgingTest.apk - see the next message
Download, running instructions included
http://yadi.sk/d/IK7Sd2y0HQt4T
(For screenshots see the next message...)
Old 12-02-2014, 07:44   #9 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Translated the ActionsPcbaTest and the ActionsAgingTest using Google and APKTool.
For "English" ActionsProductTest (now ActionsProductLineTest), see the next message.
Download address is the same: http://yadi.sk/d/IK7Sd2y0HQt4T
Can be launched normally now. (Aging test still needs started with am.)
Aging test looks like a stability test. It runs some tasks repeatedly or a period of time.
To run time tests put a video file into Movies folder and install Fishing Joy 2 game
The Following User Says Thank You to dr_moosavi For This Useful Post:
Old 12-02-2014, 07:44   #10 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Also ActionsProductLineTest now works in "English". It makes a database (plt_data.*) to the root of
the sd card from where it took the Chinese texts. So if you have tried the Chinese one, delete plt_data.*
files from your ex/internal sd card.
Download address is still the same: http://yadi.sk/d/IK7Sd2y0HQt4T
Just the "English" test apps: http://yadi.sk/d/q8DJ1Kt9HdRaF
Old 12-02-2014, 07:45   #11 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Actions' test apps in English (their own versions)
Now I found them in English, so translating them was useless...
Not edited, so must be run using am.
ActionsPcbaTest.apk - http://yadi.sk/d/jpAlMkckK82Gb
ActionsProductTest.apk - http://yadi.sk/d/jBzTYDUhK82H4
ActionsAgingTest.apk - http://yadi.sk/d/E0xTSZ7JK82aK (123MB!)
ActExplore.apk - http://yadi.sk/d/5iXNIW1mK82K2
The last one a small File Explorer from Actions.
(FishingJoy2 game for the Aging Test: http://yadi.sk/d/dhBpzkwrKNoU6)
Old 12-02-2014, 07:45   #12 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Old 12-02-2014, 07:50   #13 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Upgrade/Flash the Ainol Novo 7 Venus firmware
http://www.youtube.com/watch?v=9OZKCdkg1GY
FIRMWARE UPGRADE TOOL (Tablet Product Tool(Developer Edition) .... Ainol
Last edited by ...:::::NP™:::::...; 08-27-2020 at 00:22. Reason: YouTube Link has been correction
Old 03-27-2015, 19:30   #14 (permalink)
Member: 2319692
Hi,Dr Moosavi
How can I flesh my tablet AMD 7021 with product tool but instead fw file with img file
Thanks in advance
Old 05-19-2016, 10:49   #15 (permalink)
Member: 2574840
All the stuff in this thread has been copied from Slatedroid . com
Here is the original thread there (remove the spaces)
h t t p : // www . slatedroid . com/topic/94521-actions-tablet-tools/
Page generated in 0.33461 seconds with 8 queries
