Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 04-26-2013, 00:10   #31 (permalink)
Member: 1086393
Thanks Meter: 771
Ha..only usb
Sent from my GT-I9003 using Tapatalk 2
Old 04-27-2013, 13:22   #32 (permalink)
Member: 681090
Sonork: 100.1621067
Thanks Meter: 120
trick-works
Originally Posted by RATHISH.TR_ALUVA View Post
TRY WITH RESETTING/WIPE
1. There three buttons at front in Penta TPad
2. Press these three buttons together and then try to start Tpad by using Power Button. Once you done it It will ask you to press the button Press the top most button (Which is going to be used for back). and then it will show that your Penta TPad is resetting.
thanks-tricks works for me
thankyou very mutch
Old 05-13-2013, 16:59   #33 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
Originally Posted by Frenzy_2020 View Post
contact me. I have done this Tab, its a bit trick u need to flash the Tab with firmware
frenzy
plz help me my tab stuck in logo
Old 05-14-2013, 07:03   #34 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 136
try to update threw sd card and when u update put charger coneected bro
Old 05-14-2013, 16:01   #35 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
i already try it but still cant update
Old 05-15-2013, 12:53   #36 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Member....
download the tool from the link, extract the update.img with that tool.
After that flash with Rock Chip Flast tool...
Rk29xx ImageTools V2.1 - SlateDroid.com
Your problem solved.....
Just now i flashed the tablet with that tool and succeeded.
See the screenshot attachment...
Old 05-15-2013, 16:40   #37 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
can u give me another link
Old 05-15-2013, 16:51   #38 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
can u give me more information file or tool
thnx to help me bro
Old 05-15-2013, 18:04   #39 (permalink)
Member: 1377174
Thanks Meter: 226
thnx to help me bro
rk29_update_tool - Download - 4shared
Old 05-16-2013, 06:37   #40 (permalink)
Member: 1086393
Thanks Meter: 771
Originally Posted by ashamsu View Post
Dear Member....
please post here the firmware extractor tool and how to flash.. how to put in download mode?
My phone is in pattern lock. I have updated the fw with memory card but still pattern lock. I need to factory reset the tab.
thanks
Old 05-16-2013, 08:46   #41 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Smile
thanks
Dear Member...
BSNL Penta IS709C is Rockchip CPU based tablet. It detects as RK29 device to flash the firmware.
Download firmware file from this link and extract...
http://www.pantel.in/download/IS709C...Wifi%20CTU.zip
Dowload the tools from this link...
RK29xxImageTools_v2.1.zip
T760-AdvUpdater.rar
Extract the RK29xxImageTools_v2.1 and place the update.img to this folder and rename it to wendal.img...
Then run Runme.bat file and select 1 to unpack the file. After unpacking the flashing files will be located in temp folder of RK29xxImageTools_v2.1 folder.
Then open T760-AdvUpdater folder and open update.exe. In that select the files as shown in the attached image. All the selected files must be the files located in the temp folder.
After that turn off your tablet and connect it by pressing 3 buttons at the same time press on/off button. Now the device will detect as RK29 device, install the necessary drivers for that.
Then check whether the device detected by update.exe as Found RKAndroid rock usb. After that click on EraseIDB and the click run.
Wait for few minutes till it get completed. And then remove tablet from pc and turn on.
It will get 5 to 10 minutes to fully load....
That's all..............
The Following 2 Users Say Thank You to ashamsu For This Useful Post:
Old 05-16-2013, 09:26   #42 (permalink)
Member: 1086393
Thanks Meter: 771
Dear Member...
T760-AdvUpdater.rar
thanks bro for the awesome help. but where is the usb driver?
it says unknown device. Need usb driver
Old 05-16-2013, 10:09   #43 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Member...
Check the properties of unknown device, whether it shows vendor id & device id properly....
search by vendor id & device id or search in this link...
Welcome | www.topnotchtablets.com
Welcome! | Rockchip Firmware
Old 05-17-2013, 06:44   #44 (permalink)
Member: 1086393
Thanks Meter: 771
Dear Member...
can't flash..i tried with different port.
Is this driver problem?
Old 05-18-2013, 06:29   #45 (permalink)
Member: 375008
bsnl penta pattern lock
how to remov bsnl penta pattern lock pls help
Page generated in 0.23979 seconds with 9 queries
