01-17-2014, 17:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | [GUIDE]Topwise 013 A760G Mainboard V2.2.0 Microdigit-m700gprime Flashing Success! :) Recently I had to undergo the pain of flashing a Topwise 013 A760G Mainboard V2.2.0 Microdigit-m700gprime and after using much resources here and doing a rather timely research on google I was finally able to successfully flash it and bring the Tab to working condition. So to save some people the trouble I'd like to list out the procedure I followed and it was a success. Flashing the Tab 1. Flash your tab using livesuite with the following https://disk.yandex.com/public/?hash...y4eMyyd3IgM%3D (Link shared by courtesy of ..::One-Man::..) 2. This Firmware will successfully install and this will be default in Russian as well as the screen will be shifted. How to fix Shifted Screen 1. Now this Tab 7" is with resolution 1024 X 600 so we have to set this in the script bin of the firmware that is on the Tab , to do this we follow this method. 2. Download this script-bin HOW TO USE: First of all extract the folder script-bin from archive you just downloaded. FIX SCREEN SHIFT - Connect Tab to PC install drivers etc.(ADB Drivers etc) - execute screenshift.cmd from script-bin directory and follow the numbers Press 1. Pull script.bin from tablet Press 2. Transform script.bin to script.fex Open script.fex which is now dumped to the script-bin using notepad++ Go to Line 903 and delete that line (mu_irq_id ---irq = 1) - execute screenshift.cmd Press 4. Transform script.fex to script.bin Press 5. Push scrip.bin to tablet Press 6. Reboot tablet FIX SCREEN SHIFT - Connect Tab to PC install drivers etc.(ADB Drivers etc) - execute screenshift.cmd from script-bin directory and follow the numbers Press 1. Pull script.bin from tablet Press 2. Transform script.bin to script.fex Open script.fex which is now dumped to the script-bin using notepad++ Find lcd0_para section Edit line (314) to lcd_x = 1024 Edit line (315) to lcd_y = 600 Find ctp_para section Edit line (245) to ctp_screen_max_x = 1024 Edit line (246) to ctp_screen_max_y = 600 Go to Line 903 and delete that line (mu_irq_id ---irq = 1) - execute screenshift.cmd Press 4. Transform script.fex to script.bin Press 5. Push scrip.bin to tablet Press 6. Reboot tablet Now you can see the screen is perfectly in the middle and working fine. Now Change language and use the Tab! Enjoy! If this solution worked please take time to press thanks and also do post here if you have any issues and I would be glad to help. Best Regards, JAT Last edited by Faheem Anjum; 01-17-2014 at 18:14. Reason: added |
The Following 8 Users Say Thank You to jatchaminda For This Useful Post: |
01-17-2014, 18:05 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,311 | thread now stikcy for knowlege how to repair such problem |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
01-19-2014, 15:22 | #5 (permalink) | |
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | Quote:
BR, JAT PS:Also here's the script.bin , just push this into the Tab and it will work no need to edit codes etc. https://mega.co.nz/#!4EIDUQAT!FCsOLn..._FBK9yr3YU5XXI | |
01-19-2014, 15:50 | #6 (permalink) | |
Insane Poster Join Date: Jan 2008
Member: 673895 Status: Offline Thanks Meter: 13 | Quote:
i already download firmware and successful flash via livesuit. but tab no power on. any idea??? | |
01-21-2014, 06:13 | #10 (permalink) |
No Life Poster Join Date: Feb 2013 Location: pk
Member: 1887022 Status: Offline Thanks Meter: 102 | jatchaminda Bro i have problum can u help me plz Check http://forum.gsmhosting.com/vbb/f906...mware-1765827/ |
01-21-2014, 11:11 | #11 (permalink) | |
2. Download this script-bin HOW TO USE: First of all extract the folder script-bin from archive you just downloaded. FIX SCREEN SHIFT - Connect Tab to PC install drivers etc.(ADB Drivers etc) - execute screenshift.cmd from script-bin directory and follow the numbers Press 1. Pull script.bin from tablet Press 2. Transform script.bin to script.fex Open script.fex which is now dumped to the script-bin using notepad++ Find lcd0_para section Edit line (314) to lcd_x = 1024 Edit line (315) to lcd_y = 600 Find ctp_para section Edit line (245) to ctp_screen_max_x = 1024 Edit line (246) to ctp_screen_max_y = 600 Go to Line 903 and delete that line (mu_irq_id ---irq = 1) - execute screenshift.cmd Press 4. Transform script.fex to script.bin Press 5. Push scrip.bin to tablet Press 6. Reboot tablet | |
The Following User Says Thank You to jatchaminda For This Useful Post: |
01-22-2014, 17:17 | #12 (permalink) |
No Life Poster Join Date: Mar 2009 Location: BD/HAIL KSA
Member: 1001269 Status: Offline Thanks Meter: 226 | when i try to Transform script.fex to script.bin its say invalid and i have dump from good one can any one make it flash able .img file A10_FW_BACKUP_M700G - Download - 4shared - nokiasoft nokiasoft |
01-24-2014, 06:38 | #13 (permalink) | |
Regards, JAT | |
